Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      12-11-2017, 04:53 PM   #1
CPWINCH
CPWINCH's Avatar
734
Drives: Toyota Prius
Why Are There No Good Track Tires For 513m
I spec'd my car with the 513m 18s after learning that they are forged and lightweight since I track a lot. The only tire that comes in the correct sizes are the Michelin Pilot Super Sports which are awful on the track.
Some companies offer the rear size and not the front or vice versa. Toyo makes the R888 for the rear but not the front. I reached out them explaining that there is a market for that tire size since a lot of track guys spec the 18s but they said they arent planning on making the size needed.
I know I can always go one size down for the sidewall but a 35 sidewalls looks terrible on our cars.
What tires is everyone running on their 513m?
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
      12-11-2017, 06:47 PM   #2
FriedPiston
1973
Drives: Scraper
You can fit a 285/35/18 ET22, but max recommended tire width for the front 513M 18x9 wheel is 275 mm.
You can also move up to 275/35/18 in the front, and bump the rear tires to 285/35/18 for better tire options. However, people usually go for a square track setup, most commonly 275/35/18, 285/35/18, and a few on 275/40/18.
This means you'll be able to re-use your Klassen ID MS01 wheels by simply adding a pair of 10mm front wheel spacers, and a square tire fitment like 285/35/18.
      12-12-2017, 02:45 AM   #3
n54fanatic
Armenia
149
Drives: M4
I'm running a mix of tires with the stock sizes RE-71R front and NT01s at the rear
Follow me on the 'gram @eurocarnation @sinisterM4
Check out my Past M3 build (SOLD) here!
Check out my M4 build (CURRENT) here!
      12-12-2017, 05:30 AM   #4
elmerzasty
elmerzasty's Avatar
Poland
69
Drives: F80
I am running 285/30 18 Michelin Cups on 4 x 10" 513Ms.
      12-12-2017, 08:56 AM   #5
Circuit Hunter
370
Drives: F80 M3
Ive run 265/35/18 and 285/35/18 Hankook RS3's and they are decent and similar in overall diameter to the OE sizes. The RS3 is out of production but the replacement RS4's have the same sizes. I have no experience with the new variant.
IG: @circuithunter
      12-12-2017, 02:48 PM   #6
CPWINCH
CPWINCH's Avatar
734
Yeah ive thougt about the set ups you reccomended but the overall diameter is too small. I really dont like square set ups on the M4. This car performs much better with a staggered set up on the track. I was planning on keeping the Klassens with a square set up until i realized how much these cars benefit from extra rubber in the rear. Thank you for your advice, i really appreciate it.
      12-12-2017, 02:51 PM   #7
CPWINCH
CPWINCH's Avatar
734
I would never run mixed tires at the track personally. Not as predictable.
      12-12-2017, 02:51 PM   #8
CPWINCH
CPWINCH's Avatar
734
I considered this set up before. I am just worried about it being to small in diameter. Do you have any photos?
      12-12-2017, 02:52 PM   #9
CPWINCH
CPWINCH's Avatar
734
I wish I could run cups, unfortunately I am not a fan of the square set up on the F82 personally
      12-12-2017, 02:55 PM   #10
CPWINCH
CPWINCH's Avatar
734
Thank you so much for this recommendation. This is exactly what Ive been looking for. I loved the RS3 on my old build. Would love to see some pictures if possible
      12-12-2017, 09:53 PM   #11
Circuit Hunter
370
Drives: F80 M3
No problem. My instagram is circuithunter. My oldest posts are of my old Mineral Grey F80 with 18” Advan TCIII’s on the aforementioned RS3 tires. At the time the car was lowered on KW HAS.
IG: @circuithunter
      12-15-2017, 02:19 PM   #12
RSXDC5
RSXDC5's Avatar
707
Drives: M3
OP: You do realize that overall diameter/circumference doesn't need to be spot on if you are tracking...right? You should be tracking with DCS OFF.
DSC will adjust to different tire diameters/circumferences over a period of time/mileage as well.
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      12-20-2017, 06:55 PM   #13
CPWINCH
CPWINCH's Avatar
734
Hi RSXDC5, I am aware of this and I do indeed track full DSC off but this is more of an aesthetic choice for me. I was posting this in case someone found a tire that is similar to OEM sizing overall like the guy above helped with
      12-20-2017, 06:58 PM   #14
CPWINCH
CPWINCH's Avatar
734
Just followed, I am carmodification on IG. It looks good! pretty similar to the OEM sizing. Thanks again
      12-27-2017, 09:28 PM   #15
rx7gslse
Recovering Mazda Addict
rx7gslse's Avatar
19
Drives: 17 SO ZCP F80
I’m running 265/40 and 295/40 18” R-S4 now... first track day on them in a couple weeks..
Although I’m running 18x10/11” tires, not the stock 18s. But the tires fit!
How can I be so thirsty this morning when I drank so much last night?
      01-07-2018, 10:54 PM   #16
CPWINCH
CPWINCH's Avatar
734
Thanks for the insight! Hope you have a good time at the track
      01-08-2018, 10:49 AM   #17
aerostar
746
Drives: 2018 F80
PSS are bad on the track??
      01-09-2018, 12:06 AM   #18
Sales@wheelsdc.com
Sales@wheelsdc.com's Avatar
302
Drives: BMW
I agree, not a big fan of mixed tires
CPWINCH733.50
      01-09-2018, 08:46 PM   #19
ctgeorge
ctgeorge's Avatar
314
Drives: CIVIC M3
Back when I considered using my 513m for track duty (Now relegated to a Snow Set), I found that the Yokahama AD08R come in 255/40 and 265/40. Both of which on paper seems to be just a tad larger than the 255/40 275/40 PSS. In Theory, it should work well. Ran then on my B7 RS4 track set and they performed decently.
Ended up going with an Apex 18" staggered set w/ 275-35/305-35 Nitto NT01.
      01-10-2018, 07:01 PM   #20
CPWINCH
CPWINCH's Avatar
734
Yes. They work but not very good
f80post
