12-11-2017, 04:35 PM | #1 |
Rep 6
Will This Work? 20X9.5 & 20X11
I currently have some wheels on order, specs are below. And wanted to see if anyone had experience with a similar setup.
I did some searching but couldn't really confirm that this will work. I don't want to run spacers in the rear to make it clear the suspension and wheel well, nor scrape on bumps. Front: 20X9.5 ET 18 Rear: 20X11 ET 35 I'd like to run 265/35 or 265/30 in the front and 305/30 in the rear. The car sits on the KW H.A.S. Kit suspension. I know I'll need to raise it to clear but does this setup sound like it will work? I will attach the PDF I have showing the measurements from the stock fitment to the new setup, if that might help. Last edited by Tanaka3023; 12-11-2017 at 05:33 PM.. Reason: Size Change |
12-11-2017, 05:31 PM | #2 |
2163
Rep 4,107
305/30 with et 35 is too much. I see it rubbing around the bumper/fender.
305/25 should work. I would run 295/30 Michelin M5 tires and 265/30 front. Edit: How you got your HAS 1.75" lower? Last edited by LOW4LYF; 12-11-2017 at 05:36 PM.. |
Tanaka30232.00 |
12-11-2017, 11:10 PM | #3 | |
1255
Rep 1,160
Responded I would go 265/30 and 295/30, and from what I read the new ps4 is relatively thicker than Bmw star spec Michelin SS. Going with the 265/30 and 295/30 should be the safest bet. Also depending on when you purchased the KW HAS kit if your worried about rubbing against spring perch I heard (maybe others can confirm) KW updated with a new design/version on the kw has kit which allows for more clearance due to smaller perch design. (either way the ET 18 will be to your benefit for suspension clearance) Last edited by 4DRS55; 12-11-2017 at 11:16 PM.. |
Tanaka30232.00 Lee808230.50 |
