ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Cosmetics Modification (Exterior/Interior) Discussions
  TireRack
      05-21-2008, 05:18 AM   #1
azndavid85
11
Drives: 2007 Z4 M coupe
Please Help!!!Interior LED light replacements
I want to do LED light replacement. I am looking for Super White LED bulbs at http://autolumination.com. I have couple question regards to different type of LED bulbs because most of the diameter are different and the overall size and I couldnt find side facing led for the trunk. which would be the perfect solution for our car? and Which one is gonna fit on doom light, and 2 map light, 2 footwell, 1 for trunk and 2 for licienseplate.
$8.99 each!!
"Introducing the New SMT Tower 194 168 W5W 2825
Outfitted with the latest Super High-Flux SMT Leds
The Widest, Brightest and Best 194 168 W5W 2825 Ever Made!
Only 10mm diameter x 27mm overall"???????
$10.99 each!
"Outfitted with the latest Super High-Flux SMT Leds
Only 11mm diameter x 38mm overall"??????
$7.99 each!
"Introducing the New & Improved
Outfitted with the latest Super High-Flux low profile Leds
Designed especially for gauges, and applications requiring a large uniform field of bright light
Note: These have the all metal heat sinks for constant-on applications to reduce heat related failures
Only 9mm diameter x 24mm overall""????
$7.99 each!!
"Introducing the Super Nova
Outfitted with the latest Super High-Flux low profile Leds.
Aluminum heat sink keeps them cool in hot & smaller housings to avoid heat related failure
Designed especially for gauges, and applications requiring extra cooling
12mm diameter x 23mm overall"???
Thank in advance~
      05-21-2008, 09:14 AM   #2
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
181
Drives: Z4M
Originally Posted by MMMazing07 View Post
your going to need 2 of these
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
and 3 of these
if you want the liscense plate ones too then order 2 more of the side facing ones above. I have yet to figure out how to get a LED in the center dome light. Ill post up when i ffigure it out.
we had a big discussion about this a while ago. but i have already answered your questions in the other thread
      05-28-2008, 06:28 PM   #3
zzE85zz
zzE85zz's Avatar
Drives: 2003 Z4R 2.5i
I was unable to find an LED that would fit in the center w/o having to mod anything. I was able to make the 6LED bulb fit, had to make the center hole a little bigger with a file to make it fit. Had no problems/damage with that, end results = bigger hole, brighter interior. Also replaced all my amber interior leds to white too, now that was a challenge. posted pix in album.
      05-28-2008, 09:03 PM   #4
nyczyang27
nyczyang27's Avatar
31
Drives: z4 3.0si / 328xi
I just saw the pictures in your album.. WOW how did you change the amber leds to white??
2007 Z4 3.0si Step/Premium/Xenon/HeatedSeats/AutoTop/M6Wheels
2007 328xi Step/Premium/Sport/Xenon
      05-29-2008, 04:56 AM   #5
zzE85zz
zzE85zz's Avatar
1st had to take out the switch, panel etc. to see which kind of LED it was. Hard part was trying not to break a tab(s) off the plastic housing or worst the circuit board itself, then find out how many LEDs i needed, total came out to 150+ leds, soldering iron and steady hands..... very very steady hands.
      05-29-2008, 07:10 AM   #6
nyczyang27
nyczyang27's Avatar
31
Wow.. props.. how long did it take you to do everything from start to finish?
      05-29-2008, 02:21 PM   #7
zzE85zz
zzE85zz's Avatar
Thanks! Started taking everything out on a friday night, r&r leds finished up sun evening, took breaks of course, If i did it straight i would have to say 5-8 hrs +/- 1 or 2.
zpost
