11-03-2017, 07:58 PM | #1 |
80
Rep 317
Green injectors fitment on S65 (E85 on SC Aplic.)
So I got the Green Giants Injectors to upgrade from blue so I can run more % of Ethanol on my ESS 650 kit but I can't get the fuel rail to sit Al the way down
Has anybody here done green injectors on their car? in can't find any info on this issue. thanks. |
11-03-2017, 10:24 PM | #4 | |
80
Rep 317
[IMG]undefined[/IMG] for some reasons I can't attache the pic of how the injectors come but all you have to do to get the rail all the down is to remove the white washer from the tip and get a oring that fits snog in the injector inlet on the s65's head, tomorrow I will post my progress on this. thanks to JsL for posting the pic you Rock. and To proper style for the spacer tip. |
11-04-2017, 08:00 PM | #5 | |
506
Rep 1,385
I currently run the full lenght green injectors with the spacer on a ess 625 kit |
11-04-2017, 08:12 PM | #7 | ||
80
Rep 317
thanks |
11-05-2017, 01:18 AM | #8 | |
506
Rep 1,385
https://re-volvparts.com/store/197-thickbox_default/0280155968-big-green-giant-bosch-s60r-v70r-fuel-injector.jpg The spacer moves the rail Up about 1/2 cm . |
11-05-2017, 03:33 PM | #10 |
448
Rep 1,263
gingerbread51.00 |
11-05-2017, 07:27 PM | #12 | |
80
Rep 317
with ESS manifolds it's to dam close but it did at the with exactly 5mm spacer. |
11-06-2017, 07:48 AM | #13 |
506
Rep 1,385
I'm using this setup on my ESS kit. its not really that big of a deal tightening the clamps. I've been running this way for like 4 months. I've had to take the blower off a few times to check or change things.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
12-18-2017, 12:06 PM | #14 |
612
Rep 1,326
looking to make the switch to green injectors as well.
can someone post the link to where i can buy the 5mm spacer? do i need 4 spacers? also a reliable link to buy the correct green injectors? TIA!
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
12-19-2017, 10:32 AM | #15 |
506
Rep 1,385
you can buy them from active auto worke just call and ask.
12-19-2017, 11:47 AM | #16 |
612
Rep 1,326
great. thanks!!
