11-01-2017, 04:48 PM | #1 |
87
Rep 606
Fitment question ...need help!
Hey guys need some help on fitment
Would these fit on my M3? Would it look ok? Need spacers? If so how much... 20x9.5 et25 265/35 pss 20x10.5 et25 295/30 pss Thanks in advance! |
11-01-2017, 05:35 PM | #2 | |
3138
Rep 2,953
The front with a 265/30/20 is going to need a spacer to push the wheel out, you can run 5-10mm spacer depending on suspension and tire brand. The rear you probably want to drop to a 285 because the 295 is going to poke. 20x10.5 +25 is a very aggressive offset. Look like the wheels are for E9X M3 |
11-01-2017, 07:21 PM | #3 | ||
87
Rep 606
11-02-2017, 11:55 PM | #4 |
151
Rep 268
Depending on your rear alignment specs and tire choice you can get away with a thin 295. I'm running 20x10.5 +24 on swift suspension with negative 2.3 camber, slight toe in on a 285/30/20 Sumitomo HTRZIII with 4-5mm to play with.
2016 Alpine White F80 | Individual Opal Interior | BBS LM-R | Dinan Exhaust | Active Auto Midpipe | V-Style Lip | Vorsteiner Rear Diffuser | M-Performance Spoiler | IND Alpine White Grills | Swift Springs | Instagram: S55Journal
