05-31-2018, 10:14 AM | #2 |
Rep 46
Two part question, my passenger side fog light just went out, I believe these are LED fog lights? So is there a bulb replacement or does the entire housing need to be replaced? Also does anyone know how to remove the housing or access the fog lights?
05-31-2018, 10:53 AM | #3 |
307
Rep 1,715
Drives: 2014 650xi Gran Coupe Msport
It's more likely that you have an electrical issue than all 3 LED bulbs burning out simultaneously. I would start by checking your fuses.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
05-31-2018, 10:55 AM | #4 | |
Rep 46
05-31-2018, 12:04 PM | #5 | |
4446
Rep 7,488
In regards to fog light removal...here's instructions from the online TIS website: https://www.newtis.info/tisv2/a/en/f...ights/IexcaPum As far as the fog light itself...it appears to be a single unit based on the part database...there are no individual bulbs offered...just one single unit: Last edited by Qsilver7; 05-31-2018 at 12:18 PM.. |
upstate650306.50 |
06-04-2018, 02:04 AM | #7 |
Problem Solver
113
Rep 416
No I just had a similar issue, water got into my connection and messed it up a bit. I was able to remove the bottom grill and access the plug on the left side of the housing on the side. That fixed my issue once I cleaned out the corrosion and reseated the connection.
06-06-2018, 12:18 PM | #8 | |
Rep 46
