10-23-2017, 09:14 PM | #1 |
102
Rep 780
Brushed BBS LM Floss Design build 20’s w/ Toyo T1 Sport
Selling a set of newly refinished BBS LM's built by Floss Design wrapped & in brand new Toyo Proxes T1 Sport tires. -Faces are brushed finished and clear coated. Also had the BBS imprints painted in red to compliment the red Center caps. -Barrels are original BBS 9 and 10 inch wide pieces with the lips polished and clear coated. -Brand new Red Center caps. -Brand new hardware nuts and bolts. Used larger M8 bolts instead of standard M7 bolts for a better look. -New Toyo Proxes T1 Sport tires Specs: Front- 20 x 9 et 15 5x120 245/30/20 Rear- 20 x 10 et 11 5x120 275/30/20 This offset was achieved by using a more aggressive face to match up with the 10 inch barrel where Floss Design measured it out to 20x10 et11. The stance is very close to the aggressive 20 x 10.5 et 15 rear LM's that some guys are running. If you plug the numbers on willtheyfit.com my rears will be less aggressive by 2.3mm. Mounted and road force balanced. Installed on my car and took some pics. Put no more than 20 miles. Ended up taking them off & putting my car to stock to sell. $5000 pick up in SoCal Los Angeles Buyer pays for shipping Last edited by Kenyon; 05-25-2018 at 12:14 AM.. |
