10-22-2017, 12:01 PM | #1 |
516
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
Left front tire temp rise after lowering
After lowering with moton, the front left tire reads higher than other 3.
I did alignment 2 time. Reset temps. No crazy drive. Car pulls slightly right just like other m3/4. . Anyone has similar issues? |
10-23-2017, 09:52 AM | #2 |
21117
Rep 20,741
Drives: 2021 911 turbo
Are your cold pressures well adjusted? What lowering springs did you use? If you have a HAS, did you get the car corner balanced?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-08-2017, 01:13 PM | #4 |
1391
Rep 1,105
Is it always the left side. Mine shows higher temps depending on where the car is parked, and what angle the sun is beaming at.
///M3 2024 G80 Competition - Starting Lineup
///M4 2019 F82 Competition , 2019 G30 540i , 2008 E92 335i - Retired |
11-08-2017, 10:52 PM | #5 |
516
Rep 1,247
I also check my x5m, the left front is higher in most the case.
When I turn off engine, I do feel left front blow out high air compares to right front. Both M4 and X5M |
11-23-2017, 07:37 PM | #7 |
The G8X is a disaster. 🤮
931
Rep 988
That's unusual, because my 2015 M3 is very stable left-right and front-rear. I can correlate a couple degree temperature rise to one tire being 1 psi lower than the rest, but otherwise they're always within 3 degrees of each other. Such a large disparity suggests to me that the alignment may be off and the warmer tire is scrubbing the road compared to the rest.
