10-12-2017, 01:04 PM | #1 |
Rep 26
Tire Width Questions F82 M4
Morning all.
With these particular wheel sizes and offsets, would the stock front and/or rear tires stretch or would it fit perfectly? Also, what would be the maximum width I can go on both front and rear wheels without causing rubbing issues? FYI, I will be lowered on Macht Schnell competition springs. Here are the wheel specs and so forth: 20x9.5 ET +17mm 20x11 ET +34mm Tires: 265/30/20 fronts, 285/30/20 rears. Stock Michelin PSS off the competition package 20" wheels. Any input would be appreciated. Thank you in advance! |
10-12-2017, 09:46 PM | #4 |
1357
Rep 3,349
+34 will be close, but you'll be fine with camber; not a preferable option at all.
It also depends on how low you want to go... You'll probably be better off with a 295.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
10-12-2017, 10:15 PM | #6 |
1357
Rep 3,349
It depends on what you're comfortable with. The F8x is somewhat "forgiving", but it really depends on what you're comfortable with.
Get into these other threads and compare other setups with your same offsets and potential tire sizes with the suspension dialed in. Most of the questions will answer themselves in those threads.
10-13-2017, 05:59 AM | #7 | |
2163
Rep 4,107
295/30 should fit, since 285 et25 fit without any additional camber. Always depends on the tire brand.
