10-05-2017, 04:46 PM | #1 |
28
Rep 183
M3 E9X Wheels on M4 Help
Hi
I'll receive my M4 next week and I got a set of rims from my old M3 E9x front wheels are Et25 wide 9 and rear Et22 Wide 10,5 do you think can fit on M4 with no problems ?
Bmw E87 6MT | Bmw E87 2008 6MT |Bmw E82 2010 Auto | Bmw E92 Auto |Bmw E90 M3 6MT |Bmw E90 M3 DCT | BMW F82 M4 DCT | ------------------------------------------------------------ |
10-06-2017, 04:21 AM | #2 |
116
Rep 283
Hi, i think the front wheel is fine but the rear could be difficult with that small offset. I have 10,5 x 20 with ET34 and 295/30-20 and that's absolute borderline as my TÜV guy said. Your canadian fellow "CanAutM3" has amazing knowledge about those issues... ;-)
Kraut-Hero & (occasional) San Franpsycho
ninja228.00 |
10-06-2017, 03:04 PM | #4 |
28
Rep 183
Do you think et22 rear wide 10.5 with 275/35/19 be ok ?
10-07-2017, 03:31 PM | #6 |
254
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Mine are in other but I am using my style 220m winter setup on my f80. I bought my F80 dec 31st so I figured I would give them a shot since it was last min clear the floor for 2016 sale
If I remember correct they are 255/235 oem Porsche sizes. Next time I am at my garage, I will get my exact sizes. Not rubbing what so ever but then again they are 255/235 which are small.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
ninja228.00 |
10-07-2017, 04:24 PM | #7 |
28
Rep 183
Thanks man !
10-08-2017, 10:42 PM | #9 |
28
Rep 183
With ET22 and 10.5 wide did you test it ?
10-09-2017, 11:19 AM | #10 |
721
Rep 2,342
Yes. I'm running that setup now. Currently running 265/35-19 RE71R on 19X9.5 +25 with a 15mm spacer in front, 19x10.5 +22 275/35-19 RE71R.
This pic is when I was running the 255/275 OEM MPSS garbage. Front I ran a 10mm spacer on OEM 255/35-19 MPSS on a 275/35-19 MPSS I was able to run a 5mm spacer for an effective offset of +17. You can see in the pic there is room to go more aggressive. When I went to a 275/35-19 RE71R in the rear I had to remove the 5mm spacer since they run so wide. I've also run a 285/30-19 and it was also fine, but it looked too short vs the 265/35 I was running up front. I may revisit the 285/30-19 when it's time to replace the fronts to go to a 275/30-19. This is my street setup which used the wheels I took off my E92M3. |
ninja228.00 |
10-09-2017, 12:33 PM | #11 | |
28
Rep 183
10-09-2017, 07:31 PM | #13 |
28
Rep 183
This week I'll install the wheels so will see.
Thanks for help to all for your help information's !
10-09-2017, 11:57 PM | #14 | |
3138
Rep 2,953
You can run 15mm spacer with 9 +25, and run stock tires (255/35/19) For the rear, you can fit stock rear tire (275/35/19) with no issues, if you run a wider tire, 285/35/19 you will rub unless you play with the camber |
ninja228.00 |
10-10-2017, 01:31 PM | #16 |
2163
Rep 4,106
Positive -----> http://www.willtheyfit.com/index.php...=11&offset2=25
ninja228.00 |
10-20-2017, 10:49 PM | #17 |
28
Rep 183
I Installed the wheels I think rear are too aggressive but no rub until now.
10-20-2017, 11:08 PM | #18 |
254
Rep 1,067
What size did you end up going with?
10-20-2017, 11:35 PM | #19 |
28
Rep 183
Front et25 9.5 255/35/19 Rear et22 10.5 275/35/19
Looks be ok for city but for race track is too aggressive !
10-21-2017, 08:12 AM | #20 |
21117
Rep 20,741
Drives: 2021 911 turbo
They might look good, but they are not forged and rather heavy.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
ninja228.00 elmerzasty68.50 |
10-22-2017, 07:56 PM | #21 |
28
Rep 183
For sure are not 100% right.
