XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      09-28-2017, 09:59 PM   #1
Turbod
Turbod's Avatar
396
Drives: 2014 E84 X1 35i M Sport
Dynoed my X1 35i today
So I signed up for English Racing's dyno day a few weeks ago but had to leave before I could run to make it to my buddies wedding on time. They were nice enough to let me come back up another time to get my pulls in. The car is 100% stock and I wanted to get a baseline before adding any parts to it.
At this point I have decided to wait until spring to modify the X1. Warranty is up in March, thought it was November, so I will flash MHD in March and start adding bolt-ons.
292AWHP & 300AWTQ
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      09-30-2017, 12:21 AM   #2
Xdrive35i2014
56
Drives: X1 35I
wow, that's some nice whp there. I was really expecting more losses from the xdrive drive train. If we assume 15% loss, your engine must be making close to 340 at the wheels - stock!
Mod List: Twisted Tuning MHD tune, XHP3, ER Charge Pipe, catless DP, ER Competition FMIC, Pure Stage 2 Turbo, PURE High Flow Inlet Pipe, ER Outlet Pipe, GFB DV (Plus), Gruppe M intake, Supersprint full exhaust
      09-30-2017, 06:53 AM   #3
kiloTHREE
76
Drives: '13 xDrive28i
Never trust a Dyno for standalone numbers, comparison is it's only true use.
      09-30-2017, 10:02 AM   #4
themishmosh
36
Drives: BMW X1 xDrive35i
MHD sounds awesome but the unlocking of the DME ECU sounds like a royal pain.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      09-30-2017, 09:05 PM   #5
mcdanielvzw
mcdanielvzw's Avatar
144
Drives: 2021 X3 M40i (times 2)
Curious what yours would read with a JB4 on setting 1 and 2! 5 would need learning so you couldn't do it all at once. I need to buy an upgraded charge pipe again so I can run mine on 2 or 5 instead of just 1... the BMW stock one broke on my last X1, so I don't want to do that again.
      10-02-2017, 02:20 AM   #6
Turbod
Turbod's Avatar
396
I will never put a JB4 on my car again. I ran one for 3 years on my 335i and I am glad to have switched to MHD.
If you're mechanically inclined at all it's not bad. I'll remove the DME myself and have Ken (Wedge Performance) bench flash the DME. At this point I don't know if I just want to run a E30 tune or turbo swap.
2023 G80 M3 xDrive
      10-02-2017, 11:57 AM   #7
themishmosh
36
I wish I had someone local that could unlock the DME but I don't. I would expect the car to be down at least 5 days which I do not have the luxury of doing.
      10-02-2017, 08:16 PM   #8
mwtrogus
44
Drives: 2014 X1 35i
I pulled my ecu out and then shipped it to Twisted Tuning in NY, he unlocked it the next day when he received it and dropped it back off to FedEx and I had it back in my hands. Really only down for a day and a half. $100 for the unlock is a great deal and buy one of his coding cords too, it’s much faster than the older styles and works great for XHP flashes as well.
I have been running the e85 backend flash that Burger has out there for free stacked with JB4 for boost control and gauges on the app, etc.
      10-03-2017, 06:46 PM   #9
fiehlsport
50
Drives: '13 X1 xDrive35i
Hey, me too! Justin was really quick.
The DME removal kinda sucked, but once you remove the intake manifold once it's not that bad. I'm enjoying the freedom to switch maps now to whatever I want, and the ability to custom-tune is even better.
And I finally got my exhaust burbles. :-) (After years of being teased with my friend's 135is with the PPK tune)
      10-07-2017, 07:52 PM   #10
mcdanielvzw
144
Why do you say you'd never run a JB4 again? Bad experience with it, or just better option with the MHD?
      10-08-2017, 07:56 PM   #11
Turbod
Turbod's Avatar
396
Honestly I have a bunch of reasons I don't like the JB4. It was a great option when it and Cobb were the only options. I do not like that it spoofs values so things like load and ultimately clutch torque isn't where it should be at the increased power levels. I found it to be inconsistent with power output since it doesn't have defined timing targets, it just continues to ride the knock sensor. Actually it does have defined timing targets but since load is not load actual it is targeting values that do not make sense on pump gas and the boost levels you see with the JB4. It wasn't as smooth as stock and can only log a few parameters. I understand the extra features it has but if you look at any other platform you'll see that flash tuning is the way to go.
2023 G80 M3 xDrive
      10-08-2017, 08:15 PM   #12
mcdanielvzw
144
That's fair. I'll have to look more into the other options (MHD is the one I'm thinking of) and try it out if I can.
xbimmers
