XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      09-19-2017, 10:10 AM   #1
DavidVella98
Drives: X1 MSport
Cool What mods should I do to my new X1 MSport?
Hi guys,
I just bought me a new BMW X1 2.0 XDRIVE23D M SPORT, which will be my second car, my first car was a Polo 6n (1995) so quite an upgrade huh? :P And although it's still on the way (freight) I'm still overly excited on what mods I should do to the car.
This is the list so far:
  1. Yellow tint for the fog lamps (€3);
  2. Black Kidney grills respray (€10);
  3. MSport Covers for the grill (€6)
  4. Sat Nav from DVDGPSNAV (€333);
  5. Trunk handle camera (€30)
  6. and remap the car to 260hp/490 nm (€210)
So far I'm looking at spending at around €600. Any other awesome mods I can do to this lovely beast.
How it currently is
After messing around with photoshop :P
So what do you guys think?
Thanks
      09-21-2017, 08:48 AM   #2
DavidVella98
Drives: X1 MSport
anyone?
      09-21-2017, 10:39 AM   #3
PauloB
Drives: 2015 X1 M xdrive28
intake? makes the car sound really nice.
      09-21-2017, 11:48 AM   #4
DavidVella98
Drives: X1 MSport
Do you you recommend any in particular?
      09-21-2017, 02:44 PM   #5
gettinOld
Drives: 2014 X1 xdrive28i M Sport
No yellow tint. Kidneys look great in black but enough of the M colors on the vertical tabs. I see WAY to much of that here in Miami.
My opinion, I don’t like the stripes.
      09-22-2017, 03:13 AM   #6
DavidVella98
Drives: X1 MSport
I actually pretty like the yellow tint and the covers haha. Got a photo of your car?
      09-22-2017, 10:36 AM   #7
D Unit
93
Drives: 2013 x1 s28i
I'd keep it stock looking and lower it.
D Unit
Bay Area, CA
      09-22-2017, 11:57 AM   #8
Vidgamer
Vidgamer's Avatar
Drives: BMW X1 e84
This. If it wasn't so expensive to get coilovers, I'd do that. But none of those other things matter. If you want just cosmetic changes, I kind of like some of the spoilers, but the M-Sport version already has a nice aero kit.
Personally, I'm thinking of getting some "whiter" headlight bulbs. Philips makes some nice ones.
      09-22-2017, 02:48 PM   #9
jinda
jinda's Avatar
17
Drives: 2013 X1 xDrive35i M Sport
I'm planning to get the carbon fiber eyelid but haven't started looking for one.
2013 X1 x35i M Sport
Past: 2011 Mazda CX7 AWD Sport | 2004 BMW 330i ZSP/ZPP | 2008 Hummer H3 | 2005 Honda Civic VTi | 1997 Honda Civic ESi | 1996 Nissan Sentra SS EXi
      09-22-2017, 04:07 PM   #10
gettinOld
I have a plain AW M sport. Visually nothing done except some M style mirror covers.
      09-25-2017, 03:43 PM   #11
PauloB
I got the AFE kit
http://afepower.com/afe-power-54-125...-intake-system
      09-25-2017, 06:02 PM   #12
X1Denver
niner
16
Drives: 13 X1 Alpine Xdrive35i M
Originally Posted by PauloB View Post
His car is a diesel. Not a n20
I don’t ever suggest an intake unless you have a larger turbo.
      09-26-2017, 09:20 AM   #13
Vidgamer
Vidgamer's Avatar
Drives: BMW X1 e84
Check out their chart -- there's almost no gain (with the n20) except for a bump at 3500 RPM? Mehhh.... Might be better in combo with other upgrades....
      09-27-2017, 09:04 AM   #14
PauloB
ops didnt realize he had a diesel
      10-15-2017, 07:16 PM   #15
GTony
Australia
28
Drives: 2015 X3 F25 XDrive 28i M Sport
Hi DavidVella98, Your photo looks like an E84 with the long bonnet. These are still available in 2017?
      10-17-2017, 07:32 PM   #16
TitanSilverE46
Australia
Drives: 2014 X1 E84 , 2017 2201 AT F45
How are H7 Globes changed?
I have fitted blue "whiter" H15 globes for High Beam/DRL to my 6/2014 sDrive20i MSport, but can't work out how to remove the Low Beam H7 globes to fit my 'blue' Low beams.
These two shots are with the connection plug attached and with just it removed but I have never struck anything like this before. Normally there was a clip that unhooked from the top and swung down to release the globe. Any suggestions?
      10-17-2017, 09:35 PM   #17
Njerts
126
Drives: x3 m40i
Push in the 2 clips on the sides.
I think;-)
      10-18-2017, 02:21 AM   #18
TitanSilverE46
Australia
Not quite there yet, but this looks something close.
http://www.e90post.com/forums/showth...t=22752&page=3
I had tried to push in the side tabs, but difficult with screwdriver and not wishing to break anything ... they did not seem to move. Perhaps the dealerships have a special tool?
Further searching revealed this. The clip is not exactly the same but I might be brave enough now to try again.
Copied from http://www.e90post.com/forums/showpo...23&postcount=4
Now having learnt how to do it, I thought I'll write a summary of how it is done. It applies to low beam halogen H7 bulb in a BMW 318 and 320, European model with Hella or Valeo H7 bracket. This bracket is different to what folks are used to. It has no clip and the bulb is pushed in place to fit. To take it out one is forced to tilt it upawards before it dislodges from the bracket. Here you go,
Turn the light switch (inside the car) to "0" position so that there is no current in light circuit. Turn the forward wheel to the opposite side. Reach under the wheel arch to locate the rectangular flap. Use a coin to rotate and unlock the two lock mechanisms in the flap. Remove the flap. Use a powerful torch light and locate the round plastic window that is hiding the low beam H7 bulb. Turn the round plastic window to the left and remove it. Now you will see the backside of the H7 bulb with the brown rectangular connector attached to the two bulb pins. Do not take out the connector just yet. Hold the connector along with the back side of the bulb (single grip) and tilt the whole assembly upward (push it upward). The lamp will give way and come loose from the bracket and you can pull out the lamp. In some case side to side jiggling may be necessary to dislodge the bulb from its seating. Now you can remove the old bulb from the connector and fit a new H7 bulb in the connector. Hold the connector with the bulb and insert the bulb into the bracket, aligning the top portion first and then pressing forward the whole bulb in position. Look at the bulb from the head lamp side. There should be almost no gap between the bulb body and the reflector.
Never touch the glas part of the bulb with hands and if you do wipe it clean with spirit. Use gloves and take due precaution as mentioned in BMW's user manual. Good luck !
Sorry guys, this has been dealt before. I did not find it in my early search try. Here is the link to that old thread.
http://www.e90post.com/forums/showthread.php?t=22752
      10-18-2017, 09:05 AM   #19
Njerts
126
Drives: x3 m40i
Thanks for the update.
It seems easier than the wire hook mechanism in a confined space.
      10-23-2017, 04:54 PM   #20
GTony
Australia
28
Hi DavidVella98-AGAIN,
Would it be possible for you to Reply to my 1'st Post?
Thanks.
      11-05-2017, 06:16 PM   #21
GTony
Australia
28
Thanks.
As you can see I have a d also.
Being an old guy i prefer the original look but don't mind small changes like yours.
Your Color would look great with Hyper Silver Wheels and the many Combo's available.
There are Exhaust Systems up to expensive Quads that are made for X1's.
Chips or as you mentioned Remapping if more power is required.
Depends on your Country and Dealer Regulations.
This Forum and the Other Forum are basically for 28i and 35i Petrols. I have got fantastic information from them over the Years.
You can see my X1's Diesel Spec's. After a lot of searching and work I have based my O/Seas Purchases on a 2013 X1 Petrol 28i.
People are hear to help even if the comments you got were a bit confusing.
All you have to do is Answer and Ask Questions.
Good luck with your great car.
Tags
bmw, bmw x1, mods, msport, new car
xbimmers
