09-08-2017, 10:02 AM | #1 |
Rep 65
M4 Suggested Tire Size...neeeddddd Helppppppp!!!!!!!!
Alternative tire sizes with +3%/-2% total wheel diameter:
(WARNING: any wider tires could not fit the fenders and arches, always check it earlier (!) and in most cases you will need new rims, of course) Rim size (in): 20 Alternate tire size: 275/30 R 20 Total wheel diameter (mm / in): 673 / 26.5 Percentage diameter difference to the original (%): -0.9 interline Rim size (in): 20 Alternate tire size: 285/30 R 20 Total wheel diameter (mm / in): 679 / 26.7 Percentage diameter difference to the original (%): 0 interline Rim size (in): 20 Alternate tire size: 295/30 R 20 Total wheel diameter (mm / in): 685 / 27 Percentage diameter difference to the original (%): 0.9 interline Rim size (in): 20 Alternate tire size: 305/30 R 20 Total wheel diameter (mm / in): 691 / 27.2 Percentage diameter difference to the original (%): 1.8 interline Rim size (in): 20 Alternate tire size: 325/25 R 20 Total wheel diameter (mm / in): 670 / 26.4 Percentage diameter difference to the original (%): -1.3 WARNING: wide tire! interline Rim size (in): 20 Alternate tire size: 335/25 R 20 Total wheel diameter (mm / in): 676 / 26.6 Percentage diameter difference to the original (%): -0.4 WARNING: wide tire! interline Rim size (in): 20 Alternate tire size: 345/25 R 20 Total wheel diameter (mm / in): 680 / 26.8 Percentage diameter difference to the original (%): 0.1 WARNING: wide tire! |
09-08-2017, 10:50 AM | #3 |
Rep 65
the help i need is that i have 285/30/20 right now
i am thinking of getting new tires for the back cuz i got a nail i am thinking of going to 305/30/20 or is that stupid |
09-08-2017, 02:36 PM | #4 |
i can haz horsepowr ??
3830
Rep 1,927
09-08-2017, 02:38 PM | #5 |
748
Rep 1,478
For info - I have 305/30 rear and 265/35 front but on 19's and just recently installed MP PS4's (previously ran Bridgestone Potenza's) - no issues whatsoever with either tire set (mounted on BC Forged RS41's w/o the need for any spacers).
Individual M4 Convertible ED Sept 2014
09-08-2017, 03:40 PM | #6 |
Rep 65
hmmm see i have the 20 inch stock comp package rims for the 2018. so i am thinking 305 it will be a wider tire plus the wont get scrathced from curb damage. plus i thinkit will drive better and i ma gonna go with MPSP...
havent tried the 4's... how are they??? |
09-30-2017, 04:28 PM | #10 |
307
Rep 608
305-25 is very bad idea, the dimater of wheels is 20mm smaller, 305-30-20 - is good. but i have to go 11inch sizes tire
if you want to leave u ZCP 666m wheels - stock wheels sizes is the best what you can use, otherwise go 9.5inch from and 11 inch rear |
