View Poll Results: Which winter wheels should I go with? | |||
437M | 10 | 41.67% | |
763M | 9 | 37.50% | |
Other | 5 | 20.83% | |
Voters: 24. You may not vote on this poll |
09-05-2017, 09:38 AM | #1 |
2874
Rep 2,759
Drives: 2020 M4 ZCP / 2023 X3 M40i
M4 ZCP - 437M vs 763M Winter Wheels
I have a M4 ZCP with 666M wheels and I need to get a 2nd set for winter tires. I'm leaning towards getting another set of OEM wheels in 19s. So my choices are either 437M in silver or 763M with 19s in the rear. Which one should I go with? Are there any other suggestions? This is for Black Sapphire Metallic if it matters.
09-05-2017, 09:51 AM | #2 |
Moderator
7515
Rep 19,368
If you want to stick with OEM, I would go with 513M. They look similar to the 763M (which are far too expensive for winter wheels, I would guess) but are much cheaper. If you want them to be black, simply powder coat. Also, depending on what type of tires you are getting (standard winter tires, performance winter tires, or true snow tires), you may find 18" tires easier to source and/or cheaper.
Obviously my suggestion will not apply if you have CCB. Other OEM possibilities are the winter-specific 18" 640M and 19" 641M. Good for non-staggered winter tire setups. |
09-09-2017, 11:13 AM | #3 |
441
Rep 568
Drives: 2019 X5, 2022 i4 M50
I have 666M's for summer and 437M's for winter w/ SottoZero2's. They work great for me and look better IMHO than the 513M's.
** I can't do 18" due to CCB either Cheers,
Current: ‘19 G05 X5, '22 G26 i4 M50
Retired: F15 X5, F80 M3 ZCP, F10 535d, E84 X1, E90 335d, E92 335i, E46 330i, E39 M5 |
10-09-2017, 03:57 AM | #4 | |
327
Rep 320
BMW said 255's all round where as I'm thinking like for like and 275 rear 255 fronts? |
10-09-2017, 05:53 AM | #5 | |
116
Rep 283
Alex, please don't put those amazing M763 on as winter wheels... that's the most exciting wheelset BMW has ever offered for the F8x especially in 19/20...
Kraut-Hero & (occasional) San Franpsycho
10-09-2017, 08:12 AM | #6 |
1133
Rep 1,360
Did the same, went with 255 square. It will look a bit stretched in the rear but not too bad from what I've researched. I kinda wish I did 275 in the rear as most of my winter driving will be in the dry cold, but the skinnier tires are def better in terms of cutting through snow if you encounter it.
10-09-2017, 08:23 AM | #7 |
2874
Rep 2,759
If I did go with 763M I was going to go with M2 sizes, 19" in front and rear. But I decided to get a set of silver 437M instead.
10-09-2017, 09:20 AM | #8 | |
327
Rep 320
Out of interest, what make of tyre did you put on the 437's? I can't find many winter tyres that do a 275 |
10-09-2017, 10:42 AM | #9 | |
1133
Rep 1,360
I went with Michelin Pilot Alpin PA4s, don't even know if they make them in 265 or 275. |
10-09-2017, 01:22 PM | #10 |
28
Rep 126
FWIW - I went with the PA4's as well. I bought four 437M front wheels, so no stretch and the front wheels look fine in back, they only sit a few mm further in than the stock rear wheels, you don't really notice it. Also allows me to rotate front to back.
Mr. Hankey1028.50 |
11-11-2017, 08:03 PM | #11 | |
Christmas Poo
1029
Rep 1,180
Read...no drive, the manual. |
11-12-2017, 05:51 AM | #12 |
79
Rep 321
11-13-2017, 07:23 AM | #13 |
28
Rep 126
