08-22-2017, 07:23 AM | #1 |
4998
Rep 6,863
Recommendations please - more traction for daily driver
I currently have the factory 513m 18" wheels with PSS tires and it will be time for new tires soon so I am weighing my options. Here is what I am considering:
- Stick with factory PSS tires in oem sized 255/40 and 275/40 - Stick with PSS tires but change rear to 295/35...is this ok to pair with 255/40 front? - Switch to the new Continental Extremecontact sport in 265/40 and 285/40 Choices 1 or 2 above would be the easiest since my front tires have decent tread left and I really only need new rear tires soon. Would a 295/35 rear be ok to pair with the 255/40 front? Any feedback is appreciated! Last edited by gatorfast; 08-22-2017 at 10:39 AM.. |
08-22-2017, 08:04 PM | #2 |
587
Rep 585
Just stick with stock.
I had the similar dilemma. After much research and comparing different sizes and whatnot, I simply bought OEM rears and got them installed. For DD, stock size is fine. No need to overthink this as going larger has its own pros and cons, and I'm pretty sure R&D team considered all of those before deciding on the tire sizing when they developed the car in collaboration with Michelin. I just wish Michelin would start producing PS4 tires for 18s.
_______________________________________________
My Euro Trip Special Report, 3900 kms, 18 days, Lots of Videos +Pix! My PCD and journey back to MD My Youtube Channel |
08-22-2017, 08:45 PM | #3 | |
4998
Rep 6,863
08-23-2017, 09:24 AM | #4 | |
4998
Rep 6,863
08-23-2017, 09:27 AM | #5 |
69
Rep 193
I'd go for the PSS in 295/35ZR18 rear and OEM front (255/40/18). More traction during acceleration and better looks (similar sidewall height on both front and rear).
08-23-2017, 01:43 PM | #6 |
4998
Rep 6,863
Would there be any adverse effects to moving to a wider rear tire but keeping the fronts the same?
08-23-2017, 02:03 PM | #7 |
21117
Rep 20,741
Drives: 2021 911 turbo
Choosing tire configurations is all about finding the right compromise for you. I am convinced a lot of sound engineering went into BMW's tire selection, but they made it for a specific set of compromises. A particular person might want a different compromise, hence why it perfectly OK to vary from the OE tires. You just need to be aware that, by changing tire specs, what you gain in some area of tire performance you might lose in others.
That being said, the tread width that BMW chose for the F8X are rather narrow. I theorize that it is mostly to improve wet capability at the expense of dry capability. Going with the 295/35R18 will improve the rear tread width by a non-negligible 1.3", which should improve dry grip. However, it will have more tendency to aqua-plane in standing water. Also, while still within the acceptable range, the 295/35R18 PSS tire was not specifically designed for a 10" wide wheel, hence, you might have slightly more sluggish response in transitions due to sidewall deformation. Further, paring it with the stock 255/40R18 will reduce the front-to-rear diameter stagger and therefore likely yield more useless DSC interventions. If you are willing to accept those compromises, it could be the right choice for you .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-23-2017, 02:38 PM | #8 | |
4998
Rep 6,863
What do you think of sticking with stock size front but moving to 285/40 rear which is in fact made for a 10" wheel? Would that create DSC problems as well? |
08-23-2017, 02:47 PM | #9 |
Recovering Mazda Addict
19
Rep 127
Hankook R-S4
I'm running 265/40-18 and 295/40-18, but not on stock wheels... Probably should check widths on wheels vs tires. edit - Looks like they reccomend no narrower than 9"f/10f" wheels, so on the low side, but still within teh reccomended width range... The tires rock! https://www.tirerack.com/tires/tires...Z232&tab=Sizes
How can I be so thirsty this morning when I drank so much last night?
08-23-2017, 03:24 PM | #11 |
2874
Rep 2,759
Drives: 2020 M4 ZCP / 2023 X3 M40i
Why don't you go with 265 front and 285 rear since that's the OEM size for competition package wheels?
08-23-2017, 03:50 PM | #12 |
4998
Rep 6,863
08-23-2017, 04:49 PM | #13 |
21117
Rep 20,741
The 265/30R20(*) and 285/30R20(*) PSS are specifically designed as front and rear tires for 9" and 10" wide wheels. Not necessarily the case for any 265/40R18 and 285/40R18 tires.
08-23-2017, 04:50 PM | #14 | |
21117
Rep 20,741
08-23-2017, 05:10 PM | #15 |
292
Rep 708
OP, have you thought about the new Michelin Pilot Sport 4S? FWIW, Tire Rack rates it a 9.3 out of 10, vs. 9.0 for the PSS. Will probably go with these next time. NOTE: Might not be a good idea for track use, a couple buyers on TR said they chunked the outer tread on the track.
Cheers
Bye bye E93 M3 - Hello F83 M4! |
08-23-2017, 06:39 PM | #16 | |
21117
Rep 20,741
08-23-2017, 07:07 PM | #17 |
6580
Rep 5,304
You should try out choice 3) Continental ExtremeContact Sport. They're supposed to have better wet grip than the PSS while having the same dry grip and noise/comfort levels. Supposedly, they take a little more heat to get on, but don't get as greasy when the heat is on. They're a lot cheaper too.
The Michelin PS4 supposedly made some dry grip compromises (compared to the PSS) to improve the wet grip. Doesn't matter for you anyways because they don't come in 265/40R18 and 285/40R18. I'm gonna be going with the Conti ECS on my next set. I got to push these tires at the BMW Performance Center and they are impressive. |
08-23-2017, 07:24 PM | #18 | ||
4998
Rep 6,863
