08-19-2017, 09:36 PM | #1 |
Rep 47
Rear 19x11 +30 ?
Hello,
Has anyone successfully run 19x11 ET+30 offset in the rear with Michelins 295/35/19? On KW HAS at lowest setting. This is on an M4. I realize that this is slightly more aggressive setup than what most are suggesting to go with (+35), but has anyone done this without rubbing issues? Any pictures would be great. Thanks
///M4
08-19-2017, 09:44 PM | #2 | |
3138
Rep 2,953
You're probably going to want to run a 295/30/19. Most likely need some camber on the 11+30 |
08-24-2017, 04:28 PM | #3 |
Rep 47
Thanks.
I already have the new wheels and tires, so I'm sticking with the sizes for a while. Front is flush, but rear seems like it can use 5mm spacers (currently +35 offset). So my question was would I be safe with that additional 5mm to make it +30 effective offset?
///M4
