08-16-2017, 12:32 AM | #1 |
6580
Rep 5,304
OEM Wheels: M4 GT4 vs M4 CS
Anyone know if the M4 GT4 wheels will be available to purchase? They are the same style as the CS wheels (M-Perfomance wheels), but are way more concave.
M4 CS M4 GT4 |
08-16-2017, 04:48 AM | #2 |
21117
Rep 20,741
Drives: 2021 911 turbo
Aren"t the GT4 wheels 18"?
The concavity also likely stems from lower offsets and wider wheels (18x11). I am not sure they would meet the clearance margins that would allow BMW to make them "street legal".
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-16-2017 at 04:56 AM.. |
08-16-2017, 10:06 AM | #3 | |
6580
Rep 5,304
In any case, you're probably right about them being unavailable. Bmw probably wouldn't want to go through the hassle. |
08-16-2017, 11:17 AM | #4 |
140
Rep 187
Does the M4 GT4 run 18x11 square setup? Looks like it does. I wonder if the wheel offset is the same front to back. Interested in finding out how they pulled that off and if any spacers are being used. A square 305 tire setup will be sweet for the track!
08-16-2017, 11:58 AM | #5 |
6580
Rep 5,304
I wonder too. Unless they reworked the geometry, I don't see how they can run a square 18x11 set up without using spacers for the front. A couple folks on this forum has gotten a 18x11 + 305 square set up to work in the Apex thread. However, front spacers + very specific suspension + a lot of negative camber was necessary.
08-16-2017, 12:11 PM | #6 |
210
Rep 400
It is 18x11 square and they run a massive spacer up front. Pics in the GT4 sales brochure.
These wheels and the GT4 Ohlins setup are on my wishlist. Someone with a motorsport account needs to hook up us with some spares orders lol. |
x.shell6580.00 |
08-16-2017, 02:55 PM | #8 |
13523
Rep 8,165
The wheels are made by SAI http://superalloyengineering.com/products/wheels/, a Taiwanese company that supplies forged wheels to Ferrari or McLaren (even the P1, apparently). Some person in another thread said that the CS/ M Performance wheels have "Made in Taiwan" stamped on them so they are made by the same company, too. BTW, all other M3/M4 wheels are from Fuchs.
08-16-2017, 05:08 PM | #9 | ||
6580
Rep 5,304
08-16-2017, 08:01 PM | #10 | |
140
Rep 187
Is that the massive spacer i see in the picture? Looks like at least 25mm. I can't believe it is acceptable for a motorsports team to run that big of a spacer and not have durability concerns of putting a lot of stress on the studs and wheel bearing. They must've done something else to make it work, especially for 24 hours endurance racing. |
08-16-2017, 08:36 PM | #11 | |
21117
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-16-2017, 09:21 PM | #12 | |
6580
Rep 5,304
Kind of like this. Although the added weight might introduce more stress on the bearings, it's probably a worthwhile trade off to have the ability to run a squared set up. |
DCG783.00 |
08-17-2017, 12:16 PM | #13 | |
140
Rep 187
One other thing I noticed, and it may be an artifact of the picture angle but it seems like the rotor offset is shallower than base car. Meaning the rotor is sitting far more outboard than base car. |
DCG783.00 |
08-17-2017, 12:30 PM | #14 | |
140
Rep 187
Can somebody calculate if an 11" wide wheel with proper spacing/offset is able to keep the distance between Center Lines to be same as base car? |
08-17-2017, 12:42 PM | #15 | ||
6580
Rep 5,304
M3Tooner140.00 |
08-17-2017, 02:35 PM | #16 |
140
Rep 187
Agreed that the benefits probably far offset the reduced bearing life. More rubber in the front for better grip, Less complexity in wheels/tires that the team needs to carry, Ability to reuse tires in a any corner of the car, and etc.... But I chuckled when you said "They just need to last 24hrs at the most". I know what you mean.
But yes, if it is good enough for 24hrs of endurance racing, it's good enough for some of us that only do 20-30 minutes per session of HPDE, that's for sure. |
x.shell6580.00 |
08-23-2017, 12:02 AM | #19 |
334
Rep 624
08-27-2017, 02:44 PM | #20 |
Libertarian
71934
Rep 4,035
Those are going to be ridiculously expensive, APEX wheels and call it a day. I've tested lighter wheels back in the day, my times were pretty much the same, we're talking 20lbs vs 23lbs wheels.
I know in theory better stopping, better acceleration blah blah |
08-27-2017, 03:22 PM | #21 |
581
Rep 1,120
Are they using Ohlins or Bilstien? It says Bilstien on the GT4.
08-28-2017, 01:44 AM | #22 |
210
Rep 400
