KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
05-12-2008, 04:59 AM | #1 |
45
Rep 902
Offset Question (need help!)
So i got the HRE 441 R with these spec
Offset: 38 front 19x8.5 28 rear 19x10.0 Tires: Toyo T1R 245/35/19 275/30R19 Do you guys think it will fit my E92 M3? thanks
08 E92 M3 AW M-DCT 09 INDxRENN-SPEC Project GT-R |
05-12-2008, 02:34 PM | #2 |
BimmerPost Supporting Vendor
517
Rep 3,612
the front is going to be WAY tucked in. You will need a 30mm spacer in the front to make that work. The rears should be ok, probly still tucked in a little though
05-12-2008, 03:06 PM | #3 |
45
Rep 902
Thanks ! brandon, i am going to give HRE a call and see what they can do to change the offset. I love those wheels and i dont want to loose it.
05-13-2008, 09:17 AM | #4 |
M3Post Supporting Vendor
87
Rep 964
You may not need quite that much spacer. The stock M3 18" wheel is the same 8.5 width and 29mm offset, which is 11mm different. Asi it stands, your HRE will be tucked in a bit, and you may need more spacer depending on brake clearance. 30mm spacer would give you an effective offset of +8, which would be on the low side.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
05-17-2008, 11:14 PM | #5 |
45
Rep 175
the correct RR tires are F: 245/35/19, R: 275/35/19
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
