07-28-2017, 09:59 PM | #1 |
RELAPSED MOD ADDICT
179
Rep 432
Vp Ms109 + E85?
VP MS109 + E85 or just straight MS109, what would give me the best results at the strip? I have 10 gallons of MS109, and a bunch of E85 here at the house, trying to figure out the best mix to use. A lot of opinions on the web but no hard data to show one better then the other.. does anyone have any advice as to the best mix .
MODS: JB4 map 8 + DP+Meth+Exhaust+ CP Looking to get this figured out by Sunday, but not sure where to get the correct information! Greatly appreciate advice from those who have tried / know. Thanks!
Vehicle : 2016 /// F80 M3 DCT / Executive / M Adaptive Suspension
Mods: Evolution Racewerkes Downpipes / Maximum PSI Front Mount Intakes / Active Autowerkes Mid Pipe / JB4 Stage 3 (Bluetooth) / BMS Meth Kit / AKRAPOVIC CF Tips / VORSTEINER VFF101 Wrapped in Hankook Ventus V12.2's / BMS 12/15MM Spacers Mode Carbon Spoiler / M Performance CF Lip / RW DTM CF Diffuser / RW CF Mirrors / RW CF Fender Inserts / RW CF Grills |
07-29-2017, 07:35 AM | #2 | |
2634
Rep 2,809
I'd do E30 with MS109. Pretty simple. Actually, you're running meth. You can run more ethanol since you're running meth as well, but you need to tune your JB4 setup for it. You could probably easily do E40 or more if you know what you're doing. That said, MS109 is kinda a waste of money when you're running meth and ethanol if you are tuned properly. |
FSociety3812.50 |
07-31-2017, 06:00 PM | #3 |
BimmerPost Supporting Vendor
24298
Rep 190,975
To get best result, you need a custom JB4 map
You also need to check how much ethanol is actually present in the E85 mix to know which mix gives you the highest octane
