      06-22-2017, 02:59 AM   #1
cozmicf
Rik
Australia
24
Drives: DSB 135i 2011 DCT N55
Different sound after oil filter housing gasket change
Hey guys, I got the oil filter housing gasket changed on my 2011 BMW 135i by a mechanic today (because I found an oil leak around there) and noticed it sounded different after. I've only had this car for about 8 months so I don't know exactly what it used to sound like brand new.
The videos below have two different sounds that I had not noticed below. Can anyone identify them? Is this normal after an OFHG change?
1. Sounds like something spooling up when I rev it but not very smoothly (would turbos be affected at all by an OFHG change?):
2. Seems to come from under the engine cover, sounds like a more pronounced diesel-y sound than before (mostly in the second half of the video):
Are any of these sounds normal? I will probably take it back to the mechanic to get it checked out.
      06-27-2017, 09:52 AM   #2
Stewy_604
Stewy_604's Avatar
77
Drives: 2011 E82 135i M-Sport
Sounds completely normal to me.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts
2007 Suzuki GSX-R 750 - too much to list
Dackelone10588.50
      06-27-2017, 12:17 PM   #3
Matticus91
Matticus91's Avatar
3475
Drives: 2013 135i
Is your oil level good? Any leaks? Car throwing any codes or driving differently?
They have to remove, or at least partially remove the intake manifold to get one of the bolts for an OFHG change - it's possible they missed something when they put it back together.
The first video definitely sounds a little weird, the second one seems normal. These engines make a ton of not-so-savory sounds under the hood.
The first video almost sounds like the turbo isn't regulating pressure correctly, but if that was the case it would definitely be noticeable when driving.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq
      06-27-2017, 12:52 PM   #4
Neiman Levenson
Neiman Levenson's Avatar
258
Drives: 2008 135i M-sport
i agree with matticus, the intake manifold is extremely sensitive. I took mine off for carbon cleaning and was in a world or hurt when I re-installed it.
Ultimately, you need to use the exact torque specs and order of torquing the bolts to ensure that the manifold seats 100% with no small or faint leaks. I even had to get to new intake manifold gaskets and follow the protocol 100% to make sure it seated right and didnt give me any leaks.
your mechanic probably knows this about intake manifolds though. The usually "good and tight" or star pattern. will not cut it when torquing down the intake manifold. you have to follow exact spec is what I found
      06-27-2017, 12:58 PM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
2nd video sounds normal to me. Some cars can such air thru the rear crankshaft seal. Maybe your OFH was leaking so much that now your engine has more vacuum at idle - hence the different sound to "your ears"... which is completely normal to "our" ears.
      06-27-2017, 07:17 PM   #6
cozmicf
Rik
Australia
24
Thanks for the info everyone. I haven't gotten any DME error codes, and the oil level sensor hasn't gone off. The car drives the same as far as I can tell, and I don't really notice any decrease in power.
I haven't noticed the noise from the 1st video in a while now, so maybe it was something that only happened for a while after the OFHG change and isn't really a problem? I will try revving it again tonight to see if I hear the noise again.
Is there any easy test for checking for leaks? Would an MHD log help?
      06-28-2017, 05:55 AM   #7
brytom
Level 1 BMW Tech
brytom's Avatar
25
Drives: 2010 | N52K | 6MT
Check for vacuum leak or boost leaks?
In stock form, it should be giving you codes right away for low boost pressure if there was an issue. They are multiple sensors checking boost pressure. I don't think there is anything on the intake side that requires vacuum that it would have been touched. Only vacuum items are the turbo and exhaust flap.
In stock form, you don't need to do much if you're careful. Remove the microfilter trim, remove the air box, move some harness out of the way. I take shop air to knock any debris from falling in to the intake ports of the head. Take out the seven bolts/nuts for the intake and slide it up an inch. There is no need to to touch the DME nor the charge air pipe or throttle body.
Edit:
I forgot the main vacuum line runs from the pump over the intake to the vacuum reservoir built in to the valve cover. You can try remove the acoustic cover, should be two push down in the front you can pull up on and pull the cover forward and out of the slides built in to the intake pipe. Check the hose if it is snapped in properly and the hose after the bend down below the intake is cracked or broken. I doubt there is an issue, as a vacuum leak before the reservoir will cause issues with the exhaust flap and the wastegate, meaning you would have boost pressure faults.
      06-28-2017, 10:17 PM   #8
cozmicf
Rik
Australia
24
Edit:
Thanks for that. I think it should be ok given that I haven't seen any other symptoms or codes, and the car drives the same. If I start having problems I will give that a try.
1addicts
