      06-18-2017, 10:39 AM   #1
kevin135
Drives: black '12 135i dct
Stripped rear exhaust hanger mount
I was installing a hitch last night and had to lower the exhaust. When putting the m8 1.25 bolt back in I noticed it angled slightly and stopped about half way in. The bolt looks good so I'm assuming the female side is stripped.
Any suggestions? Is a tap the best option? I'm assuming I'd need to expand the hole to 3/8 or so?
Attached is a photo if it helps any.
      06-18-2017, 02:11 PM   #2
iminhell1
C2H5OH
iminhell1's Avatar
3915
Drives: 2010 SG 135i auto
Just run a tap through it first. Might clean it up enough to make it usable.
      06-18-2017, 08:57 PM   #3
kevin135
Thanks! I went with that approach and was able to thread the bolt easily. Hoping the threads hold.
      06-18-2017, 09:26 PM   #4
iminhell1
C2H5OH
iminhell1's Avatar
3915
If not, longer bolt and nut on top ... I think I see your finger so you should be able to get a nut on it?
      06-19-2017, 06:03 PM   #5
Stewy_604
Stewy_604's Avatar
77
Drives: 2011 E82 135i M-Sport
+1 for re-tap...glad you got it sorted. Should be fine now.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts
2007 Suzuki GSX-R 750 - too much to list
1addicts
