06-12-2017, 07:48 AM | #1 |
Rep 16
Ideal tire pressure?
I have 20 inch 343M wheels with MPSS which have been on the car for 4 months with approximately 4K miles. The recommended tire pressure per the sticker is 35 PSI. I feel the ride gets very harsh esp in warm weather after driving for a while on the crappy philadelphia roads. I tried going down on the tire pressure by 1.5 PSI, definitely helps but the steering feels much heavier at lower speeds. Don't know if this a MPSS issue and switching tires might help? What tire pressure do you guys have with your MPSS? Would appreciate any suggestions.
2014 BMW M5 CP
2016 Volvo XC90 T6 2009 BMW 750Li (sold) 2008 Honda Accord coupe (sold) |
06-12-2017, 08:16 AM | #2 | |
446
Rep 1,300
06-12-2017, 10:41 AM | #3 |
4076
Rep 5,234
33 psi for me
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
06-12-2017, 03:42 PM | #4 |
496
Rep 812
36-37 psi for every day. 38 psi driving long distance with full car. 30-35 on the street drives like the car has a flat tire.
Formally known as BMWM3NYC
06-23-2017, 09:39 PM | #9 |
Rep 16
Hmm, that's rather high! Not experimented with such high pressures in the M5 but have tried that in my previous 750Li (19s with a much cushier ride btw). It definitely made it easier to maneuver at lower speeds and generally lighter on its feet but seemed a little wobbly when braking heavily at higher speeds.
2014 BMW M5 CP
06-23-2017, 10:52 PM | #10 |
112
Rep 123
I came to those pressures by measuring tire temps at inner, outer and center tread. Gave the most consistent readings all around.
