      06-07-2017, 12:40 PM   #1
Ladydragonz
Ladydragonz's Avatar
84
Drives: '08 135i M Sport
Exclamation These electronics are KILLING ME!
I am so lost. I keep getting SOS malfunction, ac won't blow, bluetooth module consistently off, no AUX, no SAT radio, no power to car outlet/USB under armrest, and magically will come back. I have replace the FSU under the glovebox twice! I am going to check fuses later today. I am so tired of this issue reappearing, I was floating nicely for 4/5 months everything working and on the hottest day about a month ago everything went out. I am getting ready to take it to a dealer but so far I've done everything on my little 1 myself and am not ready just yet to take it in. ANY help is greatly appreciated. >W<
      06-07-2017, 12:43 PM   #2
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Has the battery cable recall been done?
      06-07-2017, 12:52 PM   #3
Ladydragonz
84
Negative, I'm unsure as to what that even is.
      06-07-2017, 12:56 PM   #4
MightyMouseTech
4338
Well, that would be a good place to start.
Dackelone10588.50
      06-07-2017, 12:59 PM   #5
Ladydragonz
84
Guess I will be looking into that STAT thanks
EDIT: scheduled my appointment to get that issue corrected
      06-14-2017, 10:00 AM   #6
Ladydragonz
84
Work done, still having this issue. Any ideas?
      06-14-2017, 11:51 AM   #7
Duesentrieb
Germany
Drives: E81 116i, F31 LCI 320d
You still haven't answered my question at the other thread.
Without the error codes it will be very difficult to help you.
Greetings
Daniel
      06-14-2017, 12:06 PM   #8
Ladydragonz
84
Greetings
Daniel
I don't have my tool on me right now, going to read the codes as soon as I get home. I haven't forgotten!
      06-14-2017, 02:34 PM   #9
Duesentrieb
Germany
Ok
I hope it will bring light into the darkness.
      06-14-2017, 02:56 PM   #10
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I would also check the connector(loose?) at the MULF com box under the trunk liner. Its in the middle center of the trunk area. While your in there also check the battery terminals for tightness.
Have a dealer run your VIN for any open recalls.
      06-14-2017, 03:21 PM   #11
MightyMouseTech
4338
Also check for any water in and around the MULF.
Dackelone10588.50
      06-14-2017, 04:09 PM   #12
Ladydragonz
84
Greetings
Daniel
There are absolutely no codes thrown right now I just checked.
      06-14-2017, 04:19 PM   #13
Ladydragonz
84
No water around the MULF or Bluetooth module checking all the connectors.
      06-14-2017, 04:20 PM   #14
Ladydragonz
84
No connectors loose
      06-14-2017, 07:16 PM   #15
12vElectronics
Drives: 2008 BMW 128i Vert
Subscribed.
The iDrive in my 08 128i is terrible as well.
2008 BMW 128i Convertible 6 Speed Manual Transmission.
      06-15-2017, 03:10 AM   #16
Duesentrieb
Germany
Mhhh...
Your battery is ok? How old is it?
      06-15-2017, 08:17 AM   #17
Ladydragonz
84
Angry
Mhhh...
Checked the battery voltage yesterday everything good, checked the alternator, good. This issue is driving me NUTS. I actually had a spare TCU from a buddy and swapped it out, and put my original one back in. NOTHING. In other news I fixed my AC. FSU is fine, the clip needs to be replaced thats going into the FSU, I had only changed the smaller black clip.
      06-16-2017, 02:18 AM   #18
Duesentrieb
Germany
Your car has a bistable relay. Maybe it's sticky. It's situated in the fuse box. You can see it at your last picture. It's between the black relay and the 60A fuse (above the torx screw).
I don't know if it's exchangeable, because it's situated on the PCB of the fuse box.
You can check the black relay too.
      06-17-2017, 02:07 PM   #19
Ladydragonz
84
What exactly am I pulling the black relay or the 30 amp fuse.
      07-04-2017, 07:27 AM   #20
brytom
Level 1 BMW Tech
brytom's Avatar
25
Drives: 2010 | N52K | 6MT
Does your car have a third module mounted under combox?
Options: Sunroof delete, Sport Package, Xenon
Mods: M Performance Suspension, BMW Style 197 Wheels/ PSS Tires, M Sport Steering Wheel
      07-04-2017, 07:58 AM   #21
Duesentrieb
Germany
It's a 2008 135i. There isn't a combox available.
As you can see on the picture: TCU, MULF and SAT radio is installed.
      07-07-2017, 08:05 AM   #22
brytom
Level 1 BMW Tech
brytom's Avatar
25
Ah yes. Sorry. So used to doing combox retrofits at work, got it mixed with the TCU.
I only see two modules. Photo is maybe 100 pixels by 100 pixels and I can't click on it. So I can't see much. TCU on the right, Sat radio on the left judging by the pink connector?
Tags
aux, bluetooth, final stage unit, fsu, fuses
1addicts
