06-04-2017, 09:07 PM | #1 |
16
Rep 37
brake squeal....
So I bought a CPO 2013 135i back in January. I didnt notice the brake squeal then until I was already on my way home. I bought the car at a BMW dealer 4 hours away so its not like I could turn around. I thought no biggie i'll slap some new pads on. I replaced the pads with OEM pads about a month later. The squeal started again about a day later after replacement. I then ordered some EBC Yellow stuff pads which I have used on my previous cars and had the front rotors shaved. Again the squeal came back about a day or two later. When I say squeal I mean so bad its as if I'm driving a city bus or something coming up to a stop light. So I ordered the stoptech slotted rotors all around from ecstuning. The squeal did come back but its not as loud and this time it comes and goes. I have no idea what else it could be... Any ideas?
06-05-2017, 12:57 PM | #4 |
65
Rep 275
I brought this issue to the dealer's attention when my car was still under warranty, and they somehow filed the pads to make the squeal go away. I don't know exactly what area got the filing, but it did the trick and they never squeaked again. I don't know if they'll touch your aftermarket parts but you might be able to get some advice from them.
You mentioned scheduled maintenance, are you still under the 4 year original warranty/maintenace plan? Pads are rotors are included with this plan. |
06-05-2017, 05:28 PM | #5 |
77
Rep 310
BMW's are notorious for brake squeal. So much so that there's notices posted in my local dealer's service department explaining the "problem." Filing the leading edge of the brake pad should help combat this, but will need to be re-done as the pads wear. Did you use the OE shims when installing the EBC pads? I just swapped out the OE (Textar) pads to Carbotech's when I did the rotor swap, no more squeal and very little dust. Performance is great IMO.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
06-05-2017, 08:15 PM | #6 | |||
16
Rep 37
06-06-2017, 11:42 AM | #8 |
43787
Rep 7,224
Don't really get any brake squeal to speak of. Maybe once or twice. Mine are pretty quiet. OE brakes.
06-06-2017, 05:27 PM | #9 |
77
Rep 310
Agree, definitely makes it sound cheap. I'd really recommend the Carbotech pads. I've been very happy with them.
06-06-2017, 08:36 PM | #10 |
850
Rep 2,276
"Noise Free" or Permatex Disc Brake Quiet on back of pads and wait min 2 hours but better overnight before install. Obviously caliper grease on tabs of the pads. I have no noise whatsoever on my Cool Carbons, never had any noise on OE's. Bav Auto probably have a video in their "blog" section.
06-06-2017, 09:32 PM | #11 | |
16
Rep 37
06-07-2017, 07:00 PM | #12 |
77
Rep 310
Basically just take a file, bench grinder, etc... and file down the leading and trailing edges of the pads to about 45 degrees.
06-09-2017, 10:41 PM | #13 |
16
Rep 37
06-10-2017, 08:53 AM | #14 |
25
Rep 33
Mine also make noise, seems to only be an issue under light braking when its cooler out for me. The jurid pads I took out were quiet, textar pads and coated Zimmerman rotors now. Should've used some crc disk brake quiet when I put them back together but didn't so back apart they come.
06-13-2017, 10:26 AM | #16 |
84
Rep 331
Try some hard braking like trigger the abs.
Your brake is squealing because she wants you to push her harder. My 135i squeals after carwash and not being driven few days after wash. I doubt the contaminant on the pads or rotors cause the problem. OE BMW brake and pads love squealing, it's so common.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust | Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) | Current: F87 M2 Competition Long Beach Blue | Completely Stock | |
