05-23-2017, 11:01 AM | #1 |
shmo
383
Rep 1,026
13 135i e88.. 19 inch rims.
any one rockin 19's on their 135i??
im thinking bout a staggered 8.5 and 9.5 19's on my 135i but don't want to mess with suspension .. any rub or need for spacers? let me know thanks guys
No sig
05-23-2017, 04:25 PM | #4 |
shmo
383
Rep 1,026
Googled It.. Im Asking About Stock Ride Height..
Obviously When U Change Ur Ride Height U Can Play With What Ur Sitting On.. Im Looking To Change My Rims.. Without Altering Ride Height..
No sig
05-23-2017, 05:46 PM | #5 |
77
Rep 310
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
05-23-2017, 05:56 PM | #6 | |
356
Rep 478
Cheers |
05-23-2017, 08:06 PM | #7 |
356
Rep 478
Also you need to be able to calculate offset of the 19" wheels you want to run as offset will dictate whether you rub or not. Rubbing has not allot to do with lowering a car or not but how much a new wheel set up pulls the wheel/tire closer to the shock in the fender or pushes it out or "pokes" out.
Google "wheel offset calculator"...you should find a link by 1010 tires that allows you to run this calculation. Our cars have a factory 49 front offset on the 18 x 7.5" and a 52 offset on the rear 18 x 8.5. You then input the factory front wheels specs and the new 19" wheel specs into the calculator and u see the difference. Same for the rear...if the calculator shows a negative number...your new set up is pulling the wheel closer to the shock. If positive...pushes it outward into the fender. The number is in millimeters....keep in mind about 10 millimeters you can get away without rubbing the fender or the shock....but without doing this calculation...its impossible to say if or not a specific wheel you like will not rub the fender or the shock. Hope this helps....and if you already know this then please disregard this post. Cheers |
05-24-2017, 02:39 PM | #9 |
shmo
383
Rep 1,026
2 Front Wheels - 7J X 17 ET:47 / 2 Rear Wheels - 7J X 17 ET:47 as per amazon add for my wheels.. I went outside and ghetto measured them(with a ruler) and they seem deeper than 7 inches.. im assuming that's what 7j means..
theyr more like 8 inch btw I have the star 256's on my car ;( ugly
No sig
05-24-2017, 03:17 PM | #10 |
shmo
383
Rep 1,026
how accurate do you think the translations are on here.. check ur aftermarket rims compared with ur stock and see if this is for real
just found it http://www.rimsntires.com/specspro.jsp
No sig
05-24-2017, 03:59 PM | #11 |
496
Rep 476
Looks like its for real but i would use the 1010 tires one. I KNOW its legit.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator# |
05-26-2017, 08:25 PM | #12 | |
356
Rep 478
Keep in mind this is my 0.02 cents but its also based on about 20 years of personal experience...some of it painful as I didn't know them what I know now |
