05-16-2017, 06:07 PM | #1 |
23
Rep 38
135I Manual Transmission fluid question froma newbe
Hello Addicts.
I have a 2011 135I and its time to change her Manual transmission fluid. Since I am located at Honolulu, its very difficult to get redline ATF here, but I can find Royal purple Synchromax manual Transmission fluid. So will the RP work for our 6MT? thank you for your feedbacks. |
05-16-2017, 09:04 PM | #2 |
3475
Rep 3,722
There's a lot of opinions on fluids, I believe Dackelone has some great knowledge on this but I am sure RP will be fine if that's all you have available. Since I don't know the market, it might be helpful for you to list a few options that are reasonable for you to purchase on the islands.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
05-17-2017, 03:28 AM | #4 |
European Editor
10589
Rep 22,992
IF the Royal Purple is a 70W80 and GL4 rated oil... than I would say its ok to use. But I really have no idea.
Can't you just order some Redline thru Amazon.com ? Here are the fluid specs on Redline's ATF D4. https://www.redlineoil.com/product.aspx?pid=51&pcid=9
05-17-2017, 12:15 PM | #6 |
23
Rep 38
Unfortunately, Amazon and other providers charge an arm & leg to deliver fluids to the island. for example if I was to use europarts ordering redline Auto Trans fluid (D4) (3 quart) and 75W90 Differential service kit......it would cost me $122. Delivery charge is $47. Some times it sucks to be on Honolulu.
05-17-2017, 12:44 PM | #7 |
23
Rep 38
I am in luck!!!! I just called Redline dealer and they gave me a local dealer who carries the ATF (D4) and 75W90! Score!!!! My baby is getting fresh reline fluids this weekend!!!
05-18-2017, 08:40 AM | #8 |
211
Rep 893
I run MTL in mine
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
05-18-2017, 10:21 AM | #9 |
1Addict
3234
Rep 7,894
Redline MTL. Done.
05-18-2017, 11:32 AM | #10 |
96
Rep 406
Drives: S54/N52
MTL here as well. Smooooth as butter
05-18-2017, 01:10 PM | #12 | |
1Addict
3234
Rep 7,894
Can always double clutch the first few shifts while it comes up to temp.
05-18-2017, 01:57 PM | #13 |
23
Rep 38
I do have a question for ShocknAwe and Stubbie Blue. Honolulu traffic is terrible during afternoon rush hours. After work going home, I drive about 5 miles fighting the afternoon traffic everyday (driving under 15MPH avg. during this stretch). So does it make sense to use MTL if you are always fighting the traffic rush hours? TKS.
05-18-2017, 03:05 PM | #14 |
145
Rep 157
I think the thicker MTL is only a problem if you are in subzero temps. At warm temps, you might feel some notchiness for the first few shifts while the transmission is cold, but then it warms up fairly quickly and will be fine. In fact the problem I had on the original fluid was that after an hour or so of city driving, it seemed to get too hot and thin to the point that I couldn't even engage 1st gear from a standstill.
05-18-2017, 03:34 PM | #15 | |
1222
Rep 1,221
05-18-2017, 03:49 PM | #17 |
23
Rep 38
I do have Amazon Prime, for some reason they would not ship it to me using amazon Prime. But the good news is that, I did found NAPA Auto has all the Redline fluids here on the island so I am good to go. I think I will try MTL.
MightyMouseTech4337.50 |
05-18-2017, 04:31 PM | #18 |
1222
Rep 1,221
It is weird what they will and won't ship sometimes. Thanks for the info about NAPA - I was going to ask you where you went!
05-18-2017, 04:40 PM | #19 |
23
Rep 38
cjb762, ya its weird. I love Amazon but sometimes it sucks.......BTW the NAPA at 1488 Hart street has all the Redline products, and also has the Pentosin dot 4 brake & CHF 11S fluids.
05-18-2017, 06:43 PM | #20 |
European Editor
10589
Rep 22,992
I know everyone loves/raves about MTL. And that's what I have in both of my BMW's(135i and an e39 540i 6sp)... but I'm gonna go back to ATF-D4... just because I remember a lighter, smoother feel. Maybe it's just in my head. IDK.
Dack
05-18-2017, 06:54 PM | #21 |
23
Rep 38
Dack, I probably try both ATF-D4 and MTL in the future just to feel for my self. I really appreciate everyone's suggestions and comments regarding what is the best TF for our ride. I tell you what,,,,, its really a blast to drive the 135I 6MT...
05-20-2017, 11:50 AM | #22 |
48
Rep 154
What about.....
I have always been leery of using ATF in a manual trans because I had a Mazda 5 speed once that burned up two sets of bearings. (It did take 300,000 km though.) I assume you guys all know the differences between straight cut gears, helical gears, and hypoid gears? ATF is not formulated like gear oil because in an automatic transmission there are mostly just bushings, not bearings per se.
But I need to do something with the oil in my 135i 6MT since it's very notchy in cold weather, and do live in the great white north where it's cold 6 months a year. I believe my car has the original oil it came with from BMW. What do you think of using high quality motorcylcle motor oil in the 135i trans? Motorcycle oil lubricates both the engine and the transmission in a bike, so it seems to me it would be Ok for my trans. |
