05-16-2017, 02:42 PM | #1 |
20
Rep 17
X5M Squeaky Brakes
Hello. X5M developed squeaky brakes on day 2 of its life.
Plan was to wait it out as parts break in, but to no avail. Now at 2 weeks / 850 km squeak level has increased to twice the volume and cringe level. Please advise: Show to dealer or wait more. Thank you for your kind advice. |
05-16-2017, 02:47 PM | #2 |
190
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
Speaking from experience, it isn't going to get better. As far as I know, the dealer can chamfer your pads, but that's a temporary fix. Others have reported an SIB to replace pads, that was even worse I've heard.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red |
05-16-2017, 03:05 PM | #4 |
462
Rep 494
05-16-2017, 03:08 PM | #5 |
190
Rep 2,245
I noticed it Day 2, drove me NUTS! I kinda got used to it, you can manage the noise by downshifting to decelerate or putting more pressure on the brake. My squeak is high pitched, and happens on light pressure, so essentially at the beginning or end of a stop.
I tried bedding, power washing, even chamfered - none worked. Other guys dont have the squeak at all which I envy. Maybe someone here has a newer solution, but Ive found ways to live with it. I do not think there is any harm done, its just one of the side effects of high performance brakes, although I disagree a car this pricey should sound like a city bus.
05-16-2017, 03:09 PM | #6 |
20
Rep 17
Ok thanks for that. Although one thing still stumps me, I can understand the sound not getting better despite hoping and wishing it would, but what must be going on in there making it get so much worse - especially on a dry day and on a full day of use...
05-16-2017, 04:18 PM | #7 |
704
Rep 1,917
1200 miles on my X6M now, and every now and then I get a little noise. I guess it just depends on your tolerance level.
Maybe it doesn't bother me because I have Pagid RS29's on my M4 for track work and they sound like a Mac truck.
Matt
05-16-2017, 04:38 PM | #8 |
166
Rep 710
for me it usually goes away after changing wheels from summer to winter, and after having it detailed. maybe the brakes get washed off enough that they don't squeak.
but eventually it will be squeaking quite loudly at every stop.
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S. |
05-16-2017, 05:42 PM | #9 |
33
Rep 176
Drives: 17' X5M/91' 325i
Garage List 2017 X5M [0.00]
2014 X5 50i MSport [0.00] 2011 X5 35i SA [0.00] 2007 X3 3.0si [0.00] 2007 335i [0.00] 2003 330Ci [0.00] 1991 325ic [0.00] |
Same here - started on day 1, still happening at 750 miles...I think I'm used to it now. Although, a neighbor of ours has a Ferrari 458 and it also makes a squeal when it stops at the stop sign by our house, so I don't feel so bad about mine making noise
17' X5M LBB
91' 325ic - Bril Red, Full Dinan Spec (past) 14' X5 50i MSport - Min White (past) 11' X5 35i SA - Black Saph (past) 07' X3 3.0si MSport Last edited by kimi_fan; 05-16-2017 at 10:18 PM.. |
05-16-2017, 07:40 PM | #11 |
145
Rep 763
Drives: '23 BMW i7 xdrive60
Just turn up the volume of the radio. I had mine replaced and they still squeaked. Weird thing is that on my M4, I don't hear any squeak at all. The other car I had that squeaked like crazy was one of my M6s.
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue |
05-17-2017, 08:48 AM | #12 |
5478
Rep 8,823
It will only get worse. Mine started at several hundred miles and now at 7K it squeaks at every stop under very light pressure. Not a big deal for having near race car caliber brakes in this car. You can learn to modulate the brake pedal to minimize the duration of the squeaking. I just deal with it and have a loud exhaust to cover up the sound somewhat.
Alan
05-17-2017, 10:43 AM | #13 | |
551
Rep 944
Have 26k miles and can tell you it doesn't get better no matter what you do. After a wash it goes away for a couple miles and gets progressively worse with more brake dust.
I also have a brand new m4 and the brakes don't make any noise. The x5m shares the same brakes as the m5/6 and notorious for the squeal. Nobody has been able to get rid of it without changing our pads to a aftermarket brand Quote:
05-17-2017, 12:08 PM | #14 |
190
Rep 2,245
I think I got used to it knowing we all suffer from this, misery loves company. So far its not worth the trip to the dealer b/c they can't remedy it. Aside from the brakes this thing is a beast.
05-17-2017, 12:09 PM | #15 |
166
Rep 710
I changed to aftermarket pads and they squeaked just as much, but didn't brake as well, so I am back to OEMs.
05-17-2017, 12:21 PM | #16 |
73
Rep 216
Can anyone confirm that there's is a BMW service bulletin for this? Even if it doesn't fix the squeak, I won't complain about a fresh set of pads! Can anyone confirm this?
05-17-2017, 12:41 PM | #17 |
226
Rep 154
I've had my X5M for 7 days now and same exact issue. I was planning on taking it in to service soon because of this issue but sounds like i'll have to start dealing with it. Very disappointing for a performance vehicle at this price.
05-17-2017, 01:21 PM | #18 | |
190
Rep 2,245
http://f15.bimmerpost.com/forums/sho...+squeak&page=3 Seems like every solution is temporary, in some cases they end up in worse results.
05-17-2017, 07:54 PM | #19 | |
145
Rep 763
05-17-2017, 10:07 PM | #20 |
Hooligan
55
Rep 680
throw some aftermarket pads on there. solved the problem for like $250 on my turbo s cayenne
2014 Porsche Cayenne Turbo S 2011 X5 5.0 Dinan - SOLD 2007 Imola Red Z4 M Coupe -SOLD 2004 Navy Blue BMW 325Ci |
05-18-2017, 05:41 AM | #21 |
360
Rep 659
Drives: 2024 X5MC LCI, 2017 F86 X6M
I noticed the same thing on my friend's X5M. I hope this isn't the issue with the X6M. It would be a disappointment and a nuisance..
05-19-2017, 04:34 PM | #22 |
41
Rep 200
my last X6M has no issue.
As every one mentioned my 2016 X6M brakes squeak like it had been on its last leg. According to the dealership, BMW used stock brake pad that has no asbestos in them. And when they are cold...that's when they squeak like a banshee. If they are in a warm state then its no issue. So in the morning...it will squeak. Even after a highway run, with the wind cooling it...it will squeak to no end. |
