04-25-2017, 11:23 PM | #1 |
198
Rep 684
as the title states my coral red door panel inserts are comming off as if the glue has dried out and is not holding anymore so i need some sort of glue to use and then put them back on how they are originaly
04-27-2017, 01:34 AM | #3 |
198
Rep 684
im talkin about the coral red part of the door its leather i believe it is now loose on the top and peeling back and there is old yellow glue on behind it and i wanna glue it back on so it doesnt get worse
04-27-2017, 08:14 AM | #4 |
2461
Rep 3,590
I'd try a gel super glue. Super glue's are cyanoacrylate adhesives which are pretty good with most plastics (the type a door panel would be made from) and leather as well. A higher viscosity gel will keep it from running away to places you don't want it.
They use ambient moisture to cure and should set up pretty quickly, a minute or so, but you should count on 24 hours for a full cure especially if the panel is trying to pull itself off (the shape is such that it doesn't touch without you pressing on it). Also try to figure out a way to press something against the panel to keep it in place while it cures, you'll have to get creative. If you're not into the super glue idea, or really want to coat everything to be sure it's a strong joint, a 2-part epoxy for plastics will do it too. Home Depot / Lowe's / Amazon etc. |
04-25-2018, 09:04 AM | #5 | |
21
Rep 30
My '08 just did the same. Was thinking of getting it recovered from the guy that did my headliner |
04-26-2018, 02:23 PM | #6 | ||
198
Rep 684
08-08-2022, 07:44 AM | #7 | |
Boost Addict
335
Rep 1,244
08-08-2022, 11:34 AM | #8 | |
1222
Rep 1,221
I'm not sure what kind of glue he used, but any upholstery shop should be able to give you a recommendation if dsocold doesn't get back to you... |
08-08-2022, 04:25 PM | #9 | |
Boost Addict
335
Rep 1,244
cjb7621221.50 |
08-08-2022, 06:46 PM | #10 |
BMW Owner Since 1971
2267
Rep 1,414
Drives: 1964 700 Sport Cabriolet
My upholstery repair guy used a fancy two-part 3M product which mixes the catalyst with the glue as it is squirted through the applicator tube. I held the panel back as he shot a bead, then pressed it back into place. It was only the top of the driver's side on my wife's 2008 128i Sport and on hers I think it may have been actual leather. Can't say exactly since now it is totaled and has moved on. It was a simple repair but I suppose the product wasn't inexpensive. It was 3M Semi-Rigid Plastic Repair #04240
tracer bullet2460.50 |
08-09-2022, 01:20 AM | #11 | ||
198
Rep 684
10-09-2022, 05:07 PM | #12 |
104
Rep 486
https://www.amazon.com/Gorilla-Heavy...21944236&psc=1
I used this to upholster the dash of my caddy and it's a great product. |
