04-23-2017, 06:23 PM | #1 |
233
Rep 165
2013 128i almost out of warranty
So my beloved 128i just hit 49k, which means the warranty is about to expire.
With that said, given that the car has been well maintained, what kind of repairs should I expect in the next 25K or so miles? Part of me wants to get the warranty, but part of me feels like the car is pretty solid and this would be a losing proposition, as the after market warranties have tons of fine print. Side note, I had some time to kill, and was looking at the 2017 230i's that I could get into, but despite the better tech, it just feels sorta bland All that being said, what do you guys think: 1. Keep the 128i and risk it with no warranty 2. Buy an aftermarket warranty. 3. Trade in the vehicle on a new BMW with a warranty |
04-23-2017, 07:57 PM | #2 |
1555
Rep 3,234
Keep the 128i. Just do scheduled maintenance. There are threads here on what should be maintained and when. Take to indy shop as the maintenance is not complicated.
2012 BMW 128i 6MT Deep Sea Blue Metallic
04-23-2017, 08:37 PM | #3 |
3475
Rep 3,722
Agreed the 128's are pretty bulletproof for the most part. Much more so than the 135's. The money you'll spend on a new car or aftermarket warranty won't be worth it unless you're very hard on the car, in which case I'd suggest the warranty.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
04-23-2017, 08:43 PM | #4 |
515
Rep 1,705
With the 128i there's not much to go wrong. Before I owned my 135i I owned a 07 328i E92 for almost 2 years. It had the reliability of a Honda Civic or Toyota Camry, nothing ever failed on me.
There's a chance of the electric water pump failing soon, but besides that all you really need to worry about is routine maintenance. I say keep your 128i
04-23-2017, 09:53 PM | #5 |
71
Rep 675
Drives: 2010 128i, manual, sport pkg
If you prefer the 128i, then definitely keep it. Not sure what might happen in the the next 25k for repairs, but just from what i've gathered on the forums, maybe small chances for the water pump, valve cover gasket, oil filter housing gasket. My 2010 is getting close to 80k, and i haven't had a single issue, although i am mentally prepared for those i've listed.
One thing i do regret is not replacing the struts and shocks sooner, not at 75k! I really should have done this at 50k, the car feels so much better now. Also, don't assume indy's are always cheaper, last summer i called around to pre-emptively replace my battery, at a very conveniently located indy quoted me $600! It ended being a DIY for about $200 with a OEM battery, but i later saw a special at the dealer about $200.
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
04-24-2017, 10:02 AM | #6 |
815
Rep 1,199
I will probably be buying a water pump and thermostat to keep around after 50K. It's going to go out in my ownership, so why not be ready for it? I could install it immediately and not even lose a day. That's all I can think of for the 128i. Everything else seems to be oil leaks or other things that won't leave you stranded. No worries here.
04-24-2017, 01:33 PM | #7 |
28
Rep 102
I am in the same boat. My 128i warranty is about to expire in July and have asked the same question. So far I have had to replace the OFH gasket leak, a key fob and replace the PDC module (due to water in the truck). I am expecting another OFH leak and water pump replacement within the next two years myself. I am leaning towards saving the money spent on warranty and find a good indy shop.
04-24-2017, 08:47 PM | #9 |
647
Rep 2,051
I have 118,000 miles on the odo. You'll be fine. Some things I had to replace since I was at your mileage are:
-Spark plugs -Driver side door lock actuator -Driver side window regulator -Battery -Crankshaft position sensor -Tires (both winter and summers) -Fluids: power steering, coolant, rear diff, transmission (6MT), oil regularly -Air conditioning refrigerant Not that scary particularly if you're no longer making car payments. I'm planning on keeping this car a long time. |
05-14-2017, 10:41 PM | #10 |
233
Rep 165
05-14-2017, 11:50 PM | #11 |
699
Rep 3,267
Drives: 2010 128i
Just from reading the forum, as well as my own personal experience, I think you should be prepared to repair/replace one or more of the following during the next few years: battery, oil filter housing gasket, valve cover gasket, eccentric shaft sensor, spark plugs/coils.
A lot of people talk about the inevitability of early water pump failure with these cars, just because it's a BMW, but I don't think I've seen too many threads from 128i owners actually experiencing failure. I guess time will tell. All in all, I think the risks/costs of long-term ownership of this car are pretty low, considering the level of performance. |
Hops128i70.50 |
05-27-2017, 12:03 PM | #13 | |
233
Rep 165
Only thing that has disappointed me so far is the tire life. I had the rears replaced at 29k, and now, at 49k they are in the yellow. The tires were rated for 65k, but all the tire shop I purchased them from is offering is a discount on a new set of rear tires. |
05-27-2017, 01:27 PM | #14 | |
815
Rep 1,199
And no, they aren't "rated" for 65K miles. They may be warrantied for that length and that doesn't include staggered setups. Usually staggered setups or non-rotated setups get a half length warranty. If you didn't rotate your tires, then the rears will wear to the wear bars around 20-25K miles on a 500 treadwear rated tire. |
05-28-2017, 07:19 PM | #15 | |
233
Rep 165
Falcon Pro G4. Not the top of the line, but considered a solid tire that generally has decent life without sacraficing performance. |
05-29-2017, 11:37 AM | #16 |
815
Rep 1,199
So is your car staggered? If not, did you rotate them?
May also get an alignment. A bit too much toe will cause the tires to wear out quite quickly.
05-29-2017, 11:31 PM | #17 | |
233
Rep 165
I also got an alignment done last December. I appears this vehicle just burns through tires quickly(Although only 20k for rears still seems too short.) |
05-30-2017, 07:23 AM | #18 | ||
815
Rep 1,199
05-30-2017, 08:32 AM | #19 |
233
Rep 165
[QUOTE=WDE82;21763966]If you're calling them the rears then I don't understand your rotation. If the fronts and rears are so different then you didn't rotate often enough.
The rears swapped side twice(which is what my old bmw SA recommended), but after I found out that was BS on BMWs part, the wheels had one complete rotation. Either way, it's only 20k miles we are talking here, so I thought I was being pretty liberal with as many rotations as I did. |
05-30-2017, 09:07 AM | #20 |
815
Rep 1,199
Swapping sides won't help much. That's why you get 25k out of them. That's what RWD cars do to rear tires. Only swapping front to rear will extend their life. Swapping left to right is a waste of time.
