04-20-2017, 10:49 AM | #1 |
1113
Rep 1,904
Canbus access from trunk module?
I just pulled out the seats in my M4 in order to install a couple of custom Recaro Profi XL's along with a Rear Closeout, Roll Bar, etc. I noticed there is a computer module and a fuse box just behind the rear seat in the trunk. I didn't have a lot of time to record the ID on the module last night...
I was going to tap the CanBus lines off the FEM Body module behind the passenger kick panel and run the wires under the rear closeout and to my VBOX racing computer/video logger (which will be mounted on top of the closeout). However, the module in the trunk behind the rear seat is obviously more convenient (if usable). Anyone know what that module is? ...know if there is any CanBus wiring going to it? ...or perhaps even have a schematic to share? Thanks in advance!
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 |
04-20-2017, 11:31 AM | #2 |
1593
Rep 3,945
Drives: 2015 M4 MG/SO
you obviously need ISTA/D for such a job and there are many modules in the rear... without a pic or more details, cant be of help. ISTA contains all schematics, location, pinout,... (aside from being The diagnostics software)
04-20-2017, 11:38 AM | #3 | |
1113
Rep 1,904
All I need to know is if there is a canbus feed to the module I'm referencing and what the wire colors or connector pinout would be... The module I'm talking about is right behind the rear seat in the middle of the floor of the trunk, right next to the fuse panel... If ISTA documents wiring colors, connectors, and locations - maybe some kind soul can look it up for me... IOW - I already have an inductive tap which will grab the data - i just need to identify the associated wires.... (There should be two of them)
04-20-2017, 01:02 PM | #5 |
1113
Rep 1,904
Yes that appears to be the module!
I don't see any wiring/connection info in your diagram though. Specifically I am looking for the PT-CAN CanBus wires. They are RED and RED/BLUE at the FEM module up front. Maybe/Probably the same colors in back (if they connect to that module at all). Not sure though...
04-20-2017, 01:05 PM | #6 | |
518
Rep 629
You can get it from the ekps though.
04-20-2017, 01:08 PM | #7 |
1113
Rep 1,904
Thanks!
I see some K-CAN wires in your pictures but many of the connector info is cut off at the bottom of your image... Do you see anything that says PT-CAN in the connector list?
04-20-2017, 01:16 PM | #8 |
518
Rep 629
See new pics. No pt can at the tcb but I think the ekps might work for you given its location.
04-20-2017, 01:18 PM | #9 |
1113
Rep 1,904
Holy Crap! I owe you a beer! (or two)
Thanks for running that down. That seems very convenient!
04-20-2017, 01:23 PM | #10 |
3515
Rep 2,005
Drives: BMW M3 2024 Brooklyn Grey SOLD
04-20-2017, 01:34 PM | #12 |
1593
Rep 3,945
ISTA/D is for diagnostics... I even wrote that for you in my post! That nice soul used that tool to answer you above and you should get it as it would help you look for what you need and much more.
04-20-2017, 02:01 PM | #13 |
1166
Rep 2,180
I would not mess with the TCB.
The ASD module in turn has CAN wires that can be accessed easily and without any interference. And it is right there in the trunk. |
04-20-2017, 02:23 PM | #14 |
Rep 19
I need a CAN tap that's unfiltered (since OBDII is filtered), and I'm thinking about using the connection to the light switch near the driver's window vent.
Are you using an IDC tap connector evanevery ? |
04-21-2017, 02:48 PM | #15 | |
1113
Rep 1,904
...and my video/data race logger (VBOX) uses an inductive tap so you don't actually have to cut, splice, or tap any wires. You just lay the two PT-CAN wires through the little inductive tap unit and it picks up the signal without interfering with it or touching it.
04-21-2017, 03:24 PM | #16 | |
1166
Rep 2,180
If the TCB goes bad for whatever reason or it start having communications problems then the taps can invalidate the warranty. The ASD module on the other hand has the CAN wires available much easier at its connector and its function is not as critical/sensitive as the TCB.
Good luck in your project. Quote:
04-21-2017, 03:31 PM | #17 |
1113
Rep 1,904
We are talking about the EKPS module and NOT the TCB module... (Check the SECOND set of schematics)
I don't have any issue considering an alternative more convenient location but where do you see PT-CAN wires coming in/out of the ASD module? It shouldn't really matter where you tap any of the CanBus network. If you trash the signal, it effects everything on the entire bus. Proximity of where you tap wrt to a specific module is not particularly relevant. ...and again, I'm not actually physically tapping anything. My device uses an inductive reader so it will not effect the signal or inductance of the circuit at all. The car will never know its there. ...and if I bust my Warranty I'll accept the consequences. I'm not one of those guys who tries to hide anything from my dealer. So, if you know of PT-CAN wires going to the ASD, which connector and pins are they associated with? (Also be aware that there is more than one CANBUS: K-CAN, KCAN-2, PT-CAN, PT-CAN2,... I need PT-CAN for "PowerTrain" data. K-CAN has completely different data....) Thanks!
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 04-21-2017 at 03:37 PM.. |
04-21-2017, 03:39 PM | #18 | |
1166
Rep 2,180
Post# 4 shows the TCB -Telematics Communications Box.
Disregard: ASD module uses K-CAN. Quote:
04-21-2017, 03:41 PM | #19 |
1113
Rep 1,904
Yes - but Post #6 is what we are talking about. Post #4 has been discounted/updated during the thread...
04-24-2017, 03:15 PM | #20 |
1113
Rep 1,904
Right where you said it was! Thanks for making things easy!
04-25-2017, 08:45 AM | #22 |
1113
Rep 1,904
Inductive taps are not rocket science. They just detect the signal in wires without piercing the insulation. They basically work the same as ammeter clamps...
However, your solution must be capable of using an inductive clamp. (You just can't go to the hardware/electronics store and buy an "inductive clamp"). I'm pretty sure the clamp itself requires a bit of power to amplify the inductive signal it detects. Here is a link for the inductive clamp used by the VBOX: http://www.racelogic.co.uk/usastore/...OX-Pro-and-HD2 Here are the photos I got from the VBOX vendor showing their clamp being attached to the PT-CAN wires located under the passenger kick panel. The process is obviously the same for attaching them near the fuel pump controller just under the Pass B pillar (I didn't think it necessary to take any of my own photos)...
aboulfad1592.50 |
