04-19-2017, 08:58 PM | #1 |
Ex '87 Carrera
248
Rep 1,259
Who's running Eibach Pro Kit lowering springs?
If you are, can you fit 235's up front?
I'm running Eibachs with 18x8.5 VMR 810's in front (ET45) and I don't know if I can get away with 235's or not; am thinking of playing safe with 225's... Any success or fail stories? ianc
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
"I got 328 loaner and was impressed with performance. It feels much faster than my 135i." - MOCKBA |
04-22-2017, 12:28 PM | #2 |
16
Rep 68
I am running an eibach pro kit on 18's also. My front set up 225/40/18 for the tires up front. I'm running 255/35/18 in the rear. So far it looks good and doesn't rub.
Not 100% with the 235's, but having the kit you also know the drop in the front is pretty low so it might be tight. |
04-24-2017, 01:23 PM | #3 | |
545
Rep 1,233
I have a Bilstein B12 kit (includes eibach pro kit springs), but I also have dinan camber plates which gives me about 1/4" extra height, not to mention extra negative camber. I'm running 225/40/18 on OE 18" wheels with a 12mm spacer at the front so that means it's like an 18x7.5" wheel with ET35. Never had any issues. I think a 235 would work but it would be close. Use the wheel size calculator and compare back and forth to see, something like this: http://www.willtheyfit.com/ |
04-25-2017, 02:22 AM | #5 |
aiming for 450.....
304
Rep 2,910
Are you running stock control arms?? I'm running a TC Kline setup but have camber plates and the M3/1M control arms and it gives me the clearance I need with a 235/40 and also a 255/35 (Both 18x8.5)
You may wind up needing either the camber plates or the control arms or both.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
04-25-2017, 12:11 PM | #6 |
225
Rep 376
Eibachs with 235s
I am running Apex ARC-8s in front with 235s on a set of Eibach Pro-kits. I had a set of Comp 2 A/Ss and they did rub very occasionally. I did remove camber pin from strut mount to allow some negative camber. I only rubbed a bit occasionally ie: in/out of driveways with a passenger
I have now switched to 235 Firehawk Indy 500s and they are more of a rounded corner profile as compared to being very square with previous tires. No rubbing at all now. Removing camber pin will help by allowing you to bring the tops of the tires in. M3 lower control arms will add another .75 deg of neg camber if you wanted. You can see the rounded edge in this pic. Excuse the dirt.
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid |
04-25-2017, 10:59 PM | #7 |
Ex '87 Carrera
248
Rep 1,259
GoodMoodley, how wide are those rims and what's the offset? Any side-on pics of the wheel to see the clearance?
My camber pins are long gone and I'm running the M3 control arms and tension rods up front, but no camber plates... Was thinking of Conti Extremecontact Sports as the next set of shoes. Have the DW's now and like them a lot... Thanks for the input guys... ianc |
04-26-2017, 09:11 AM | #8 |
225
Rep 376
It is 18x8.5 ET45. I don't have side pic with new tire but I do with the old tire.
04-26-2017, 01:15 PM | #9 |
77
Rep 310
I'll be throwing in the Eibach Pro-Kit springs tomorrow (currently rolling on 17" steelies for winter). Summer shoes are 225/255 MPSS on 261M's. I have a set of 12mm spacers that I'm going to test once she's lowered. I'm thinking it will rub with some trimming / fender rolling. Thoughts?
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
04-26-2017, 02:14 PM | #10 | |
183
Rep 536
