Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      04-19-2017, 12:50 PM   #1
495evo
58
Drives: 2008 CZ4A, 2016 F80
Has anyone seen this on there dash???
No pictures sorry. Couldn't replicate the message. Literally just came out of the dealership after second oil change parked on the side of the road and pop the hood release to see if all is fine. As I release the latch a message on the dash says to be cautious or careful engine compartment is hot. WTF is that??? And yes they did road test the car after the oil change. Is it normal to get that after and oil change and tech road testing it. I saw the guy pull out the lot. Tops 3 to 4 minutes he was back. Did not include this in my previous post b/c I just remembered after reading through some threads.
      04-19-2017, 04:07 PM   #2
Vigilant
Vigilant's Avatar
305
Drives: Cautiously fast
I believe this message occurs when you pop the hood after the engine has warmed up. Make sure the hood has been closed properly.
This message does not signify an issue with your vehicle. You should be fine.
2022 BSM G80 Comp X-drive
      04-20-2017, 03:08 PM   #3
dzu
119
Drives: BMW M4 F82 Austin Gelb DCT
Hot engine, you might get hurt if you touch anything. Opening the hood means maybe you wanna touch something..
MasterP721.00
      04-20-2017, 05:46 PM   #4
AlpineWhite_F80
AlpineWhite_F80's Avatar
82
Drives: 21 G80 M3C, 21 X6 M50
Nothing wrong with car, the car is just telling you to be careful when opening the hood since most of the components under the hood are hot.
f80post
