04-09-2017, 02:16 AM | #1 |
22
Rep 49
Help!!!!!! I'm rubbing in the front with new wheels
I recently got 19" wheels on my 135i and currently have eibach lowering springs and am rubbing just in the front when sharp turning or cornering. After trying different things I came to the conclusion that the best thing would be to reinstall my OEM springs and after trying that it was close to impossible to get them back on. So Im stuck..... rolling the fenders probably wouldn't be enough and i need a way to make the car higher. I was thinking coil overs but have heard that coil overs on their highest setting might not be enough. Does anyone know of any coil overs that have higher ride heights than others or can be adjusted higher than other ones. Or have any kind of advice??
04-09-2017, 05:31 AM | #3 |
13523
Rep 8,165
Post specs of the wheels
Putting ill-fitting wheels on and raising the ride height is just plain wrong
04-09-2017, 12:33 PM | #4 |
3475
Rep 3,722
Just get 18" wheels and you'll be fine... 19's rub on these cars.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
04-09-2017, 10:29 PM | #5 |
Ex '87 Carrera
246
Rep 1,259
Some are fine with 19"; it's not about the rim height but the offset.
Who knows what the OP bought? The fact that he didn't post the specs indicates he probably has no idea... iand
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
"I got 328 loaner and was impressed with performance. It feels much faster than my 135i." - MOCKBA |
04-10-2017, 11:31 AM | #7 |
77
Rep 310
+1 for posting the specs on the wheels. To make 19's fit, you'll need correct offset(s), play with height, camber, fender rolling.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
04-10-2017, 11:44 AM | #8 | |
815
Rep 1,199
Others saying 19s don't fit, that's silly. You can still have the same circumference as the 18" setups. This is all about offsets and widths. Has nothing to do with wheel diameter. |
04-10-2017, 11:31 PM | #9 |
22
Rep 49
The wheels aren't the problem they are VMR wheels 19x8.5 front ET45 and 19x9.5 rear ET57. My question was strictly suspension... I'm not going to get 18 wheels or change the width of my tires. I know what can fix the problem I was just curious what other options there may be.
04-11-2017, 12:15 AM | #10 |
Ex '87 Carrera
246
Rep 1,259
I'm also running VMR 810's (ET 45 & 58), and Eibach springs. No rubbing at all, but for now I'm only running the stock 215 & 245's.
What size tires are you running? ianc |
04-11-2017, 01:17 AM | #11 |
22
Rep 49
04-11-2017, 01:20 AM | #12 |
22
Rep 49
04-11-2017, 09:52 PM | #15 |
116
Rep 264
Do you have the camber set all the way negitive already? In case you didn't know you can remove the alignment pin on the top of the strut, loosen the three nuts and push the strut in to get probably a half a degree more negitive camber... maybe would be enough?
04-12-2017, 12:58 AM | #16 |
22
Rep 49
I haven't tried that yet will be trying that tomorrow Thanks!
04-12-2017, 09:07 AM | #17 |
116
Rep 264
04-12-2017, 09:15 AM | #18 |
4338
Rep 6,196
Just get the Dinan fixed ones. That is what I use, and I run 245's in the front with zero rubbing. But I did not do something silly like run 19's.
04-12-2017, 03:39 PM | #20 |
4338
Rep 6,196
04-12-2017, 04:03 PM | #21 | |
815
Rep 1,199
MightyMouseTech4337.50 |
04-12-2017, 05:32 PM | #22 |
22
Rep 49
I removed the alignment pin and push the strut all the way over and i'm still rubbing.
