04-07-2017, 09:12 PM | #5 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Seems OK to me but I'm also not an expert. I'd rather they get the camber more even when it's adjustable, which it should be both front and rear for you.
They always want to get the toe "in the green", but i'd rather have about half the recommended toe if I were running around twice the normal camber. Some even prefer no toe if running much camber, since the toe when combined with camber is what really wears out tires. I'm also a little confused as to whether your front or rear toe is toe in or out, but it must be appropriate since it's "in the green".
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
04-07-2017, 10:19 PM | #7 |
214
Rep 988
04-08-2017, 12:24 AM | #8 | |
198
Rep 684
i added several photos from different angles. I did knock out the alignment pins i noticed the left side is more towards the motor, but the right side isnt and im definetly gonna loosen the shock mount and push it towards the motor more for more camber. I feel either the alignment machine was glotches or somethings up |
04-08-2017, 06:46 PM | #15 |
121
Rep 2,037
I assume you had camber plates. How low are you? If not really low, something is off. You can knock readjust the strut tower to at least reduce the camber on the more cambered sized. Rear is adjustable but if you have 3deg front, may as well have 2deg rear.
04-09-2017, 12:06 AM | #16 |
198
Rep 684
oh i am definetly decently low and i have the alignments pins knocked off and i have the m3 control arms but still... thats alot of camber. do you think this can benefit handling having this much camber like this??
04-09-2017, 11:00 AM | #17 |
121
Rep 2,037
That explains it. I'd leave it like it is. Yes, camber generally helps handling, especially front camber with our cars. See how you tire wear goes, if you are eating up the inside of your front tires, especially on the higher camber side, try to move that strut tower out and get a new alignment at a shop that will reduce your toe to about half the recommended level, or even see if they will look at 1M recommendations and put your car at those.
04-10-2017, 02:00 AM | #18 | |
198
Rep 684
