      04-06-2017, 11:15 AM   #1
autopiezasford
Drives: 2012 135i
Donwpipe
If I install only the downpipe in my 2012 135i DCT ,I will see some benefits ?
It is advisable to do that? I know that the check engine went on.
      04-06-2017, 02:02 PM   #2
Jorgensen54
Jorgensen54's Avatar
No_Country
104
Drives: 2008 AW/AG 135i 6MT
If catless, yes you're reducing restriction of flow through the immediate hot side exit of the turbo.. but that CEL counters that unless you use some sort of DP fix(BMS products). Same applies for some downpipes with catalytic converters.
Do it right and you'll get some gains in hp/tq. Plenty of threads around here on the topic.
      04-07-2017, 10:15 AM   #3
Stewy_604
Stewy_604's Avatar
77
Drives: 2011 E82 135i M-Sport
I'd go with a tuner product (JB4, MHD, Cobb) at the same time to take full advantage of the DP upgrade and avoid CEL. All depends on what your overall goals are for the car and other mods you have planned. What have you done to the car? What else do you have planned?
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts
2007 Suzuki GSX-R 750 - too much to list
      04-07-2017, 04:42 PM   #4
Tiron
12
Drives: 2009 135i
I data logged the results of my N54 catless downpipe install. These tests were all run in 3rd gear, with ambient outside temp around 70 degrees, and engine fully warm. Each test was done from a full coasting fuel cut condition, meaning the turbos had no load and minimal shaft speed in order to maximize lag time. I had a Cobb stage 1 tune.
I am high altitude with 100k miles, your results might be different. I honestly didn't "feel" much of a difference, I would get a tune first.
Stock downpipe results:
1000rpm start
6 psi time: 3.841s @ 2201rpm
12psi time: 5.194s @ 2798rpm
3000rpm start
6 psi time: 0.755s @ 3222rpm
12psi time: 1.200s @ 3415rpm
5000rpm start
6 psi time: 0.354s @ 5099rpm
12psi time: 0.655s @ 5275rpm
Catless downpipe results:
1000rpm start
6 psi time: 3.090s @ 1977rpm
12psi time: 4.150s @ 2500rpm
3000rpm start
6 psi time: 0.650s @ 3218rpm
12psi time: 0.959s @ 3356rpm
5000rpm start
6 psi time: 0.301s @ 5159rpm
12psi time: 0.555s @ 5265rpm
      04-08-2017, 09:20 AM   #5
autopiezasford
Drives: 2012 135i
My car is stock .Only the catless DP. I'm planning a JB4 and a K&N drop in filter
      04-08-2017, 10:00 AM   #6
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
Won't get much out of the K&N Filter, the stock intake box is just to restrictive once tuned- consider a different Intake. Cheapest intake is the BMS DCI. I prefer to recommend the AFE Momentum GT but it's not a budget friendly intake but is the better performing of the intake options.
      04-10-2017, 12:13 PM   #7
Stewy_604
Stewy_604's Avatar
77
You'll need the JB4 or a alternative tune to take advantage of the DP and defeat the CEL.
1addicts
