03-26-2017, 09:03 PM | #1 |
18
Rep 84
Digital speed display
My 135i is less than one week in my garage and I'm still learning.
I found that a pull on the "cruise control" stalk will change the centre digital display to show the current speed digitally but it will revert once the stalk is released. I couldn't find this in the owner's handbook. Is it possible to set this digital readout on? |
03-26-2017, 09:14 PM | #2 |
88
Rep 524
You can code it in.
Example of what it looks like: http://www.1addicts.com/forums/showt...php?p=13957151
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 |
Dackelone10588.50 |
03-26-2017, 10:04 PM | #3 | |
3475
Rep 3,722
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
JP-1M171.00 |
03-27-2017, 06:48 AM | #4 | ||
13523
Rep 8,165
Dackelone10588.50 |
03-27-2017, 07:01 PM | #6 |
European Editor
10589
Rep 22,992
v-max digital speedo display...
M3 digital speedo... As stated above... you can have this digital speedo display(selected thru the BC button) coded to your car. You can have it read the same as your speedo, or have it display the "true" vehicle speed.
Many coders can do this for very little money(<$20). Or use a remote coding service or just purchase BMW Carly app(for your phone) and buy a OBDII dongle(from Amazon, etc) and code it yourself. Here is a better pic from the interwebs... " V = xxx"
03-28-2017, 10:46 AM | #7 |
3475
Rep 3,722
Yes I've done it with my Carly adapter and app. Took 5minutes and was very easy. Lots of other fun stuff in there too
Dackelone10588.50 |
03-28-2017, 06:10 PM | #8 |
18
Rep 84
Cheers. I've heard that a cheaper solution is available that requires a downloadable file and an adapter but the Carly app looks promising. Would you be able to provide a link to the adapter and any instructions? I've already found the Carly app site.
03-28-2017, 06:15 PM | #9 | |
European Editor
10589
Rep 22,992
Carly OBDII adaptors....
https://www.amazon.com/s/ref=nb_sb_s...=2XBYM3U7UPHMG
03-28-2017, 06:57 PM | #10 |
903
Rep 1,003
Drives: 2008 BMW 135i (E88 N54 6AT)
I did this this morning after reading this thread. Thanks guys.
I'd recommend following the hardware recommendations of the MHD threads - OBDII adapter, USB OTG cable & Android tablet. That way you'll be able to use the same setup for Carly, MHD and xHP. I had all the hardware (have a JB4 BEF via MHD) - it took about 10 minutes from buying the app in the store, to having it all coded and driving off. Dead easy, point and click. |
Dackelone10588.50 |
03-28-2017, 11:23 PM | #13 |
18
Rep 84
03-29-2017, 12:34 AM | #14 |
88
Rep 524
The way that a particular OBDII adapter connects to your phone/laptop depends solely on the adapter. Some are wifi, some are BT, some are even hard wired.
03-29-2017, 01:13 AM | #15 |
18
Rep 84
So if I intend to just "set and forget" then the cheapest OBD-II adapter will suffice? I'm not that interested in running a phone app to show real time data whilst I'm driving (I just want to switch on/off some of the car's dash data).
03-29-2017, 05:03 PM | #16 |
88
Rep 524
Nope, not all adapters can code. For instance, I have a "read only" adapter. Make sure the one you choose is compatible with the app/software you want to use.
03-29-2017, 08:00 PM | #18 |
Rep 126
I chose a cheap amazon adapter. It does the job well for the speedo on the dash and the 5 turn signal blink. If ur in the LA area feel free to message me. I'll do the coding.
03-29-2017, 08:42 PM | #19 |
18
Rep 84
