03-23-2017, 06:12 AM | #1 |
16
Rep 37
rotor replacement options m sport pack?
So I recently replaced the front brake pads on my 134i w/m sport pack because they were squealing. After replacement it stopped for a few days then started again. I'm thinking its because I have rust on the rotors but not sure.
What are some rotor replacement options out there for OEM size rotors. I dont want to do a big brake kit or anything like that, I think the brakes are good as it is. |
03-23-2017, 09:10 AM | #2 | |
3475
Rep 3,722
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
03-23-2017, 10:09 AM | #3 |
77
Rep 310
Depending on the mileage, you should've probably just replaced the rotors at the same time. Bedding pads to new rotors is ideal. Did you scour/scuff the original rotors to help the pads bed into them and wear the coating off the pads?
From what I can see, BMW's with OE pads are notorious for brake noise, I remember even seeing a notice to this effect in the Service department during one of my visits on my X5. My E82 still has OEM brakes (replacing in a month or two) and the brakes are very squeaky. I've got the MPBK on my X5 with Carbotech pads, they're low dust but noisy at low speeds or light application (squeaks). For OE size replacement rotors you have a few common options: -Zimmerman blanks -BMW OE blanks -BMW M Performance Slotted / Drilled (slotted / dimpled rears) -ECS 2-piece Slotted / Drilled fronts Check the brakes and suspension forum, lots of good information there.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
03-23-2017, 09:25 PM | #4 |
16
Rep 37
I replaced them with the OEM pads, car has about 27k miles on it. When I replaced the pads the old pads were pretty low so I thought for sure that would fix the squeals.
03-23-2017, 10:44 PM | #5 |
Ex '87 Carrera
246
Rep 1,259
Squealing pads typically occur because they're vibrating against the rotor and or caliper piston, not because they're low or the rotors are rusty (?). Usually when installing new pads, it's recommended to coat the contact surface on the back of the pad with some kind of anti-squeal compound. Did you do that when you replaced them?
ianc |
03-26-2017, 10:07 AM | #6 |
815
Rep 1,199
Rust on rotors isn't doing it. Pads scrape clean the area they contact.
Do a good bedding. Look up a general bedding procedure. Basically it involves many hard slows from about 70 mph to 5 mph in rapid succession. Since you didn't replace the rotors, the pads are not formed to their surface and will need an aggressive bedding process. |
03-26-2017, 10:06 PM | #7 | |
3475
Rep 3,722
https://www.zeckhausen.com/catalog/i...Path=6446_6443
03-27-2017, 06:54 AM | #8 |
13524
Rep 8,165
Properly rinsing the brakes with water when washing the car also helps with brake squeal. I've found out that when they're dirty, they tend to squeal.
03-27-2017, 04:18 PM | #9 |
850
Rep 2,276
I never have any squeeking. Obviously bedding is your 1st action. Secondly as suggested above, coat the back side of each pad with "Noise Free" (Bav Auto), Permatex Disc Brake Quiet or similar product.
04-04-2017, 09:18 PM | #11 |
16
Rep 37
04-04-2017, 09:49 PM | #12 |
3475
Rep 3,722
The parking brake is likely not adjusted well, it's actually a fairly common issue.
04-10-2017, 03:50 AM | #13 | |
18
Rep 84
04-10-2017, 11:28 AM | #14 |
77
Rep 310
I just ordered a set of ECS 2-piece slotted/drilled rotors (front), ECS slotted/drilled rears, and Carbotech 1521 pads. I'll report back once I throw them on. I'm looking forward to being rid of the excessive brake dust on the BMW OE (Textar) pads.
04-10-2017, 12:29 PM | #15 |
45
Rep 194
