      03-19-2017, 03:09 PM   #1
mr.fabulous
mr.fabulous's Avatar
211
Drives: Women Crazy
Chirping Interior Blower
Every time I decelerate, the interior blower motor in my car chirps. Pretty loudly, actually. From the time I start to brake until I am at a total stop. If I turn the fan up all the way I do not hear it... but it's loud at that point and so who knows. I do not have to brake hard, every time I come to a stop. Every time. I hear nothing if I turn the fan all the way off.
Attached is a picture I took a few months ago for another thread regarding the connector at the fan burning out (which I believe is/was a water problem, but honestly I haven't been back to that thread since). This is taken looking up from the right side front footwell with the bottom of the dash removed (maybe the glovebox too, frankly I can't remember). This is my interior blower motor? Does this just drop out? For a car so difficult to work on, it really would be a hoot if the interior blower motor would come out so easily... every other car I've ever worked on required removal of the dash to get to this.
RealOEM shows this too http://www.realoem.com/bmw/enUS/show...diagId=64_1453
Any thoughts? I feel like I should be replacing this before it stops working altogether.
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
      03-19-2017, 05:13 PM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Sounds like the bearing in the fan is going, replace the fan. I would also replace FSU blower resistor(#2) on that RealOEM diagram.
Also... checkout this thread... (which I think you have seen before)
HVAC blower intermittently does not work. Solution: wiring is faulty spans across sev
http://www.1addicts.com/forums/showthread.php?t=1206142
Appreciate 2
      03-19-2017, 09:30 PM   #3
EndOfAnEra
EndOfAnEra's Avatar
515
Drives: AW X3 35i Msport + S2000
Mine chirps only when I make a left-hand turn lol.
Eventually I know I'll need to replace my blower motor.
Appreciate 2
Matticus913474.50
Dackelone10588.50
      03-20-2017, 09:48 AM   #4
Matticus91
Matticus91's Avatar
3475
Drives: 2013 135i
Had the same issue in my last 135i, just replace the fan and you'll be good.
But if Dackelone is telling you to do something additional, do it.
His word is Gospel
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq
Appreciate 2
Dackelone10588.50
      03-20-2017, 09:59 AM   #5
mr.fabulous
211
Drives: Women Crazy
Does it just drop out? What did you un-bolt?
      03-20-2017, 10:38 AM   #6
mr.fabulous
211
Drives: Women Crazy
ECS has the part from Valeo, incl the regulator, for $135. Winner. Their product description includes this:
"If a peculiar squealing noise is present when using your HVAC system, a new blower motor may be needed. Located behind the glove box within the vehicle dash."
I still find the location of this thing to be quite remarkable (easier to get to than, say, a fuse... that's not normal).
Dackelone10588.50
      03-21-2017, 08:41 AM   #7
Matticus91
Matticus91's Avatar
3475
Drives: 2013 135i
I didn't do it myself, I'm all about warranties lol. Good luck!
      03-21-2017, 10:12 AM   #8
Matt@EuroJerks
496
Drives: 2021 Jeep Cherokee
Thank you for this. I have been wondering what was going on with my "noise" Mine too also makes more noise during left hand turns.
Is there a DIY on this?
On ECS website there are a few different versions (Valeo vs Vemo) what is the difference?
      03-21-2017, 10:41 AM   #9
dandandan
102
Drives: 2012 135i N55 DCT
Mine is chirping on medium speed intermittently. Must be the change in seasons, but definitely sounds like the blower bearing is dry.
      03-21-2017, 11:31 AM   #10
Havocsteve
82
Drives: 2011 E82 135i
Mine makes a chirp noise when it's cold out so below 5 degrees celcius. Only when you come to a stop with the brakes as well. I'm assuming the bearing needs to oiled as it's dried up (or becoming) and its from the vibration of braking. I can't be bothered to remove the dash. For some reason this seems like a huge task. I have done stuff before but it was on my first BMW, 1987 E30 325IS. It seemed so simple back then.
      03-24-2017, 12:22 AM   #11
Cosmoslux
Drives: 2011 128i AW
Mine is doing the same - under braking in cold/rain. I don't think the dash needs to be removed to get at things.
      03-25-2017, 07:07 AM   #12
bluebeemer
Dinan S3, VRSF FMIC,Inlets,Whiteline RSFB, M3 arms
Drives: 2009 135i MT
FWIW my blower in my previous 1999 323i chirped lightly for the last 80,000 miles and ~8 years. It never gor much worse or went out.
      03-25-2017, 06:06 PM   #13
Southjersey128
Southjersey128's Avatar
43
Drives: 2008 128i
2008 BMW 128i  [10.00]
Mine too, left turns only. I'll replace it eventually.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
      03-25-2017, 06:29 PM   #14
HyeWarrior
747
Drives: 2012 135i DCT
Definitely will be needing this in the future
      05-20-2018, 12:48 PM   #15
mr.fabulous
211
Drives: Women Crazy
I just added my experience to the DIY for the interior blower (mine altogether stopped working today, good thing I had a replacement ready to pop in).
      01-11-2020, 07:08 AM   #16
saxybimmer
Drives: 2008 BMW 128i
My fan quit working earlier this week, so I came to this thread, did some reading, watched the video and fixed it myself. For now. Surprised again how easy it was to do this. The motor was really tight and wouldn't free spin, so I sprayed the bearing areas with some PB Blaster low odor stuff, and just kept spinning by hand until it felt a little looser. Plugged it back up and let it run while hanging from under the glove box for a few minutes. Unhooked and sprayed again. Worked fine this morning. The wiring looked fine. My 08 128i is part of the recall, and I've had 3 conversations with the closest dealer about fixing it, but they have to wait on parts and call me back (since early November &#128580 Guess I'll call them again Monday or try the next closest dealer.
It blows fine, but the weird thing is that the defrost and floor blows warmer than the center position. Fooled with different combinations of floor, center and defrost for 30 minutes and the floor and defrost would follow whatever temperature I selected, but the center was just blowing ambient air.
1addicts
