      03-15-2017, 03:37 AM   #1
razvanx77
Drives: BMW F34
Error when trying to code BMW Professional CD
Hey guys, I just replaced my BMW business cd with a BMW Professional that works perfectly on all functions.
The main issue that I have now is the fact that I am not able to code the bmw professional with ncs expert. I am getting this error:
041 Error CDH.C CDHCheckIdent 3
Falscher SG-Codierindex A_E65R: CODIERINDEX = 03h RAD1.C02: CODIERINDEX = 02
2041 Error COAPI2.CPP coapiRunCabd 6
Falscher SG-Codierindex CODIERDATEN_LESEN
I was able to code my old bmw business cd without any problems, but somehow this one I can't,
The main reason I want to do this is because I have an external subwoofer with AMP.
Using business cd, the subwoofer worked perfectly, now with professional I can hear high sounds from the subwoofer and the bass kind of sucks.
any advice?
thanks
      03-15-2017, 04:30 AM   #2
Duesentrieb
Germany
Drives: E81 116i, F31 LCI 320d
Have you changed the FA?
      03-16-2017, 01:18 PM   #3
razvanx77
Drives: BMW F34
not really.. can you tell me what you mean by that?
      03-16-2017, 10:08 PM   #4
ianc
Ex '87 Carrera
ianc's Avatar
246
Drives: '10 TiAg 6MT 135i
FA = Fahrzeug Auftrag, or in English, VO, or Vehicle Order.
The VO is stored in two modules for redundancy, usually the CAS and NFRM. By coding the correct VO to these modules, other modules will then automatically assume the correct attributes for the indicated equipment if an NCS profile without manipulation is used to code them. If a profile with manipulation enabled is used, then the contents of the FSW_PSW.MAN file is used instead. Google a bit...
ianc
      03-17-2017, 05:44 AM   #5
razvanx77
Drives: BMW F34
Thanks, I managed to do it. coded 663 and deleted 662 from the VO.
did FA_write to frm and cas and then executed job to rad2 with man empty.
Everything works perfect now.
thanks!
      03-18-2017, 10:16 PM   #6
ianc
Ex '87 Carrera
ianc's Avatar
246
Good work...
ianc
1addicts
