03-06-2017, 12:06 PM | #1 |
Rep 67
Any Luck On Track Tires?
Has anyone out there had good luck finding track tires (e.g., R888, R-S3) that'll fit in the restricted front space of the 1 Series?
Currently I have Apex wheels 8.5 front and 9.5 rear. Over the last 3 years I've run Mich PSS 225/255, RE-11 225/255, RE-11 235/265, and currently Nexen Sur4 225/255. I've had some track rub (but not on the street) with all of them to varying degrees. For this season, I'm wanting a track tire like R888 or R-S3 or something equivalent. I have a spreadsheet with the specs for 11 tires per Tirerack. But in the front wheel well I have extremely restricted space, like 3 mm diameter and 3 mm inside at the struts. It's pretty tight. The situation is so depressing that I'm thinking of going widebody in the front. Any thoughts or suggestions?
2011 135i 6MT, Cobb FMIC, Stoptech ST-60, Pagid RS-29, Castrol SRF, Goodridge G-Stop, Apex EC-7, Dinan Front Sway, Ohlins R&T, Swift 400/500, Vorshlag Camber, M3 lowers & bits, Diffsonline 3.08 3-clutch, Sparco Ergo/Evo, Schroth Hybrid, RRT welded 4-point hoop
DD: BMW 328xiT Prior: 2000 323iT 5MT, 2000 Z3 2.3 5MT, 2001 325iT 5MT, 2009 128i 6MT |
03-08-2017, 04:05 PM | #2 |
I sold my M5
Rep 25
Check in the STU/STX chat thread:
http://www.1addicts.com/forums/showthread.php?t=1109383 I think several people fit 245's or 255's with the right offset in the front. I know I have Seen 265's in the rear, and I think 275's are also possible with the right offset. In the front is reallly is a game of getting the right offset to clear the front strut and not kill the fender.
01 325Ci | 08 535xi Sport Wagon |09 135i | 4runner | Old Ass Cessna 150J
00 Dinan S2 M5 -SOLD 98 M-Roadster - SOLD |
03-08-2017, 05:00 PM | #3 |
Beachtown Bill Collector
582
Rep 1,062
Drives: 2012 135i
I've got a square set of 235-section Toyo R888s mounted on 16x8.5 Kosei K1s. No fitment issues.
03-08-2017, 06:02 PM | #4 |
California-bound
385
Rep 1,480
Search. A bunch of us are running 255's in the front of the car. Roll your fenders, use stiffer springs so you don't rub and have a lot of negative camber. I'm running 17x9 with 255 in the front, without issue.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
