02-28-2017, 08:50 AM | #1 |
16
Rep 52
HU_NBT2 retrofit
Hi
I have a HU_NBT2 retrofitted, everything works now except TCB and I am unable to get a GPS signal. From posts I read, my factory nbt comes with a usb3 cable for TCB however nbt2 comes with a new adapter for use with TCB2 I can leave without the telematic communications function as only SOS call is supported at where I am located; problem I would like to solve is the GPS signal as I read nbt2 relies on getting it through ATM - TCB2. Is there a way to code nbt2 to get its GPS signal from the blue input plug located at the back of it which is dedicated for a GPS attena, I have connected my factory blue cable to it but is not working looks like it is still waiting signal from ATM. I have tried setting SYSTEM_GPS_RECEIVER to aktiv. Thanks Cel |
03-04-2017, 08:14 AM | #2 |
16
Rep 52
I managed to get it solved through following:
HU_NBT2: SYSTEM_GPS_RECEIVER to aktiv GPS_FROM_NAVI to aktiv ADAS_GPS to not_aktiv TELEMATIC UNIT change from ATM to off (So it fails over to GPS attena) |
05-24-2017, 05:59 AM | #3 |
Rep 14
Hi Cel,
I'm planning to make also retrofit of NBT2 to my 2015 M3, now I have NBT only. What all is necessary? Do you have any tutorial for coding? Any problems with VIN protection? Thank you in advance for any reply. Radek |
