02-20-2017, 09:24 PM | #1 |
11
Rep 93
Brakes
Anyone had issues with brakes ? Does not seem powerful enough .. coming from an M5 so that might just be something relative, but not sure if anyone else has had similar issues .. thanks !
///2017 X5M Donnington Gray/Mugello Red Interior
B |
02-20-2017, 09:31 PM | #2 |
34
Rep 144
Considering the car weighs about 1000 lbs more that could be why. Ive seen people upgrade to 6 piston front and 4 piston rear brembos but your looking at probably spending another 7-8k and from what I've heard they won't fit the stock or winter 20's but should be fine with 21's. Cheers
2015 Alpine White X6M (Akrapovic, ER Downpipes)
2008 Alpine White M6-6MT (Fully Modded S85 w/ Dinan, RDSport, KW, Akrapovic, and Brembo) |
02-21-2017, 02:05 AM | #3 |
Rep 45
The brakes aren't as impressive as the acceleration and handling that's for sure, but I do think a bit of it is in the brake feel. Different pad choice may improve things somewhat, something more aggressive. The stock units seem to be very low wearing/durable units, so a softer performance pad could help out. Making sure theyre bed in correctly too. Definitely cheaper than a bigger break kit.
02-21-2017, 08:48 AM | #4 |
12971
Rep 18,716
I notice that the brake came brand new in the car is not fully bedded.
I managed to bed one of my customer's car stock brakes, and it felt much better. As far as softer pad, be careful on what you wish for. Softer pad or more sticky pad, usually make noise. Upgrading to Brembo 6 piston front and 4 piston rear will be much better.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-21-2017, 06:45 PM | #6 |
1977
Rep 4,225
C&D has my 14 M5 stopping with standard brakes 70-0 in 165 feet and the 15 X5M stopping 70-0 in 152 feet. Not sure what the problem is.
Edmunds has the M5 at 111 feet versus 104 for the X5M for 60-0. Last edited by gblansten; 02-21-2017 at 06:51 PM.. |
02-21-2017, 08:27 PM | #9 |
fuck this field
2192
Rep 2,605
Probably because at that point the tires are far more important than the brakes. Once the brakes stop the tires from spinning, it doesnt matter what size brake kit you have on.
BMW family... for now.
02-21-2017, 08:29 PM | #10 |
1977
Rep 4,225
Agreed. Just wanted to make it clear which brakes were used in that test because it would probably come up.
paliknight2191.50 |
02-21-2017, 08:32 PM | #11 |
68
Rep 308
A stock 911 Turbo S (~3600 pounds) stops 70-0 in 144 feet vs a stock X5M (~5260 pounds) 70-0 in 152 feet - 8 feet longer with ~1600 pounds more weight.
02-21-2017, 08:32 PM | #12 |
fuck this field
2192
Rep 2,605
No thats understandable. for the F80/F82/F83 the difference in braking power between the regular setup and the CCBs is only noticeable on the track since the CCBs handle more stress and dont fade as the regular ones do.
02-21-2017, 08:43 PM | #13 |
1977
Rep 4,225
02-21-2017, 10:45 PM | #14 |
12971
Rep 18,716
Don't forget proper bedding.
Good stuff if not setup properly will not function as designed.
02-21-2017, 11:44 PM | #15 |
122
Rep 254
I was having this exact same thought. The braking issue is more noticeable with the winters hat have less tire on the rear.
One thing I can't help but think is part of it is the single piston rear calipers. One thing I'm going to do is go with stainless brake lines. There may also be some truth to the stock pads being too passive. If you check on iDrive it shows service interval for the pads at something like 35k or more.
Current: 2019 M5 Competition | Frozen Black | Black Extended Leather | Executive Package | 706M 20" (winter) | ANRKY AN14 21" (summer) | Remus Exhaust | High Flow Air Filters | XPEL Stealth
02-22-2017, 06:39 AM | #16 | |
11
Rep 93
B |
02-22-2017, 07:31 AM | #17 |
456
Rep 493
I would just stop worrying about the current stock X5 M brakes - they are very good and way overdesigned for even German Autobahn's repeated 130 mph start/stop traffic and you may notice some fading only after quite a few high speed laps on some "curvy" tracks, but unlikely to ever happen on street driving.
60 mph stopping distance depends from our tires, not our brakes -- and, maybe, also a little from the ABS settings, which look to me a little on the conservative side -- to keep furious truck driving grannies safe? |
02-22-2017, 09:33 AM | #18 |
510
Rep 709
Agree with others that the "bite" of the brakes will improve with proper bedding in. If you feather it for stops over and over and over again, it won't feel as though the brakes are as effective as they actually are.
02-22-2017, 06:43 PM | #19 |
603
Rep 1,206
the cold brakes have no bite but once you get some heat in them its good. 6 piston vs 4 piston doesn't matter if the 4 pistons are larger then the 6.
I didn't know I couldn't do that. But I did know I couldn't do that.
