02-07-2017, 05:10 PM | #1 |
Rep 121
Portland, OR help with Throttle Actuator Replacement
My car has started throwing codes and going into Limp Mode. Looks like its the throttle actuators that need to be replaced.
Was wondering if anyone in, or around, Portland has done the replacement themselves? I found a couple DIYs on here but I havent messed around much with my car. The last time I did anything to my car was installing Orion halos on my E46 M3. If anyone in Portland would be willing to help, or knows a shop that can do it without charging an arm and a leg that would be a great. Thanks |
02-07-2017, 05:39 PM | #2 |
Rep 35
If you were closer to seattle I'd give you a hand. I just got done fixing mine. If you follow along with the diy guide it's not to complicated.
02-07-2017, 10:55 PM | #4 |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
I tackled this myself with only basic hand-tools in a matter of 4-ish hours. Patience is key, the DIYs out there are pretty damn great guides. Something I might recommend, depending on the mileage of the vehicle is to consider lumping both actuators and the idle control device into the project as the three units are all housed inside the V and removing them together makes re-installation a breeze.
If you're looking for a shop recommendation, AR Auto Service in Lake Oswego is on-point. You'll likely make a shop for life if you choose them |
02-15-2017, 01:45 PM | #5 |
337
Rep 407
Drives: E92 M3, E46 M3, NA Miata
^ seconded for AR Auto. They handle service on my E92 and are building my E46 track car. Great bunch of guys.
