01-16-2017, 09:13 AM | #1 |
i can haz horsepowr ??
3839
Rep 1,934
Need help: Swift springs and tyre sizes
Hey all. So I have a set of Vorsteiners in 19's coming in now (eyeing a set of Signature wheels next ) and I need to figure out what tyre size to run on my F80 M3 that has Swift springs. I don't want any rubbing (obviously!) or DSC intervention at higher speeds.
The wheel sizes: 19x10 et 25, and 19x11 et 34 I've narrowed my the choices down to RE11's, AD 08R's, and MPSS. Ideally I would like to run a 265/35 in front and a 305/30 in the rear, however I'm completely oblivious as to whether or not there'd be rubbing and what not with the Swift springs. Can anyone help? I've tried asking in the Swift springs megathread, but to no avail. Thanks everyone!
Dakar Yellow G80 M3
Ivory White Interior @dakar.g80 #savethemanuals Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3 |
01-16-2017, 09:28 AM | #2 | |
256
Rep 928
I would run 255/35 front and 295/30 rear MPSS. Believe it or not you will end up having more tread or about the same in the rear (resulting in a similar look). Also the stretch of a 255 on a 10 in wheel would would Change the diameter slightly making it smaller than the rear as a result of the stretch alone. With 31 or 32 psi in front and 32 or 33 psi rear it might even end up being a little more (around .25+ smaller than the rear).. I've personally owned a 265/305 setup it is definitely aesthetically pleasing and functions great. The setup I am recommending is very similar and should be maybe even more compatible.
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
01-16-2017, 10:43 AM | #3 |
2163
Rep 4,108
01-16-2017, 07:55 PM | #4 | |
3839
Rep 1,934
I understand that MPSS typically run less wide than the competition, but are they taller/bigger in diameter? I'm really concerned about rubbing. Thanks! |
01-16-2017, 08:03 PM | #5 | ||
256
Rep 928
01-19-2017, 10:16 AM | #6 | |
1106
Rep 1,085
OP: I suggest 265/35/19 and 295/35/19. You'll have enough room to fit a credit card through.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
mercedesc63256.00 |
01-19-2017, 05:33 PM | #7 | |
3839
Rep 1,934
Is there an aftermarket suspension setup that would allow me to run a 305? The Swifts are stiff as hell, and I'm considering other options at this point.. especially if it opens up tyre options. I'm just looking for a modest drop at this point. Thanks Jimmy! Last edited by AhsanU; 01-19-2017 at 05:41 PM.. |
01-19-2017, 05:56 PM | #8 | |
1106
Rep 1,085
01-20-2017, 04:39 PM | #9 | |
3839
Rep 1,934
I would've gone for a 265/35 and 295/35, but the only option offered in those sizes are MPSS, and since you say that AD08's are extremely wide, I'm now only looking at the RE-11. The RE-11 is offered in 265/35 and 285/35, is this viable? Or should I look into a 285/30 in the rear as the guy in the thread with Rotiform's did? In regards to negative camber - I'm all for it, but my understanding is that negative camber slightly hinders straight line performance as there's less contact surface. If this is the case, I'm assuming the extra 10mm would still outweigh the negative effects of dialing in negative camber? Thanks again Jimmy, you're a cornucopia of vital information.
Dakar Yellow G80 M3
01-21-2017, 10:46 AM | #10 | |
1106
Rep 1,085
As for camber, it helps with cornering performance but not great for straightline grip/tire wear for daily driving.
