01-08-2017, 10:44 AM | #1 |
262
Rep 1,616
Smog readiness
Thought i'd post this to help others having the same issue.
If you reset your ECU/Clear codes/Change your battery you also end up resetting all of your readiness sensors. If all of your sensors aren't "ready" you can't pass your smog test (in certain states). Most of the sensors will become ready just from regular driving but 1-2 or two sensors seem to never become ready even after hundreds of miles of driving. Eventually I figured out that you have to drive the car for ~5 minutes between 40-60mphs @ under 3k RPM.... which to be honest are parameters i'll never meet on a normal basis... My suggestion if you have a OBD dongle is to download a free app called ODB Car Doctor, this app has a feature that lets you check OBD readiness. Just leave the app open while you're driving so you can see when all the sensors are ready. Get on the slow lane of the freeway when there is no traffic and set your cruise control to 55mph and make sure you are in a gear that will put you at under 3k rpm.... after about 5 minutes your last two sensors should be come ready.
01-08-2017, 11:48 AM | #2 | |
1092
Rep 1,318
I'm sure dealers don't drive around just to pass inspection. On vw/audi there'sa program called vcds where you can go through a set of instructions until everything passes but im not sure for bmw |
01-08-2017, 06:52 PM | #4 |
36
Rep 131
For my ESS supercharger I had to install a specific readiness tune to get the car to pass as the stock tune does not allow those readiness codes to be set.
01-09-2017, 11:20 PM | #5 | |
262
Rep 1,616
Anyways, i'm mainly speaking of when you reset the ecu on your own to clear a code.
01-09-2017, 11:25 PM | #6 | |
262
Rep 1,616
I did some research online and it seems that the O2 sensor usually doesn't become ready with normal driving. Out of all the methods I found, the one i listed above seems to work the best. I actually ended up resetting my ecu and testing the method 3 separate times and every time it worked perfectly for me. The Carly dongle should work, the OBD Car Doctor app is free so it doesn't hurt to try. Just DL the app and see if you can connect with the OBD car doctor app. This is for an iPhone, i don't know if that app is available for android. Although i'm sure there are other free apps that have this feature.
01-11-2017, 11:56 AM | #7 |
IG: @dj_dub
1804
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
To sum things all up...just Google: BMW Drive Cycle and it'll explain everything and how to get each monitor to be in ready state.
I had to do this recently for SMOG, but could not get the o2 sensor to kick on no matter what I did.
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
05-03-2017, 04:47 PM | #8 |
541
Rep 979
question. once readiness is set for all sensors, does it hold those settings until you flash the ecu again, or do you need to do the cycles over again and get smogged right after readiness?
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
05-03-2017, 05:06 PM | #9 |
BimmerPost Supporting Vendor
3387
Rep 7,542
Will stay ready until a fault appears, until battery is disconnected, or until its flashed.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
10-03-2018, 02:42 PM | #10 |
407
Rep 732
Very annoying... I drove 55 mph under 3000RPM for 15minutes. In 7th gear, Did not brake and only changed to 6th gear once.
Still not Ready. I have to try again tonight. Will see if autostore has OBDII Tester I can buy.
2016 BMW M4 ZCP, 2011 BMW M3 ZCP, 2015 BMW I3
SOLD-2015 BMW M4 Convertible ,2006 Porsche 911,2011 BMW Z4,2001 BMW 330ci |
10-03-2018, 02:56 PM | #11 | |
e90noob
1588
Rep 1,862
i don't know how i would be able to achieve "readiness" on any public roads around me there's no way i can maintain such speeds for such times
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
10-03-2018, 03:06 PM | #12 |
328
Rep 742
10-03-2018, 03:19 PM | #13 | |
IG: @dj_dub
1804
Rep 1,452
The 20-30mph one I did on empty side streets in industrial areas I knew wouldn't have any stop lights or stop signs. The 40-60mph one I did on the freeway of course, cruising 55mph in the slow lane both around 1am.
10-03-2018, 05:03 PM | #14 | ||
804
Rep 980
ridiculously frustrated right now who needs a drink
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
10-04-2018, 12:08 AM | #15 |
407
Rep 732
It is stock. The car was not driven for 3 years, battery died and check engine light was on. Gave it to dealer and they replaced battery, cleared the check and reset the sensors. I now have to smog it and it's a pain. Will try driving again tonight.
02-15-2021, 11:15 PM | #16 |
128
Rep 250
I’ve been having problems with my secondary air pump being “not ready” need to register my car so I can drive it without it being impounded but of course there’s always something. Driven it well over 1000 miles and let it idle for 10 minutes every day when I wake up. Running out of ideas and might just sell the car out of state if I can’t get it to pass smog
Car is stock |
02-16-2021, 03:26 AM | #17 | |
5865
Rep 6,637
Take it to bmw, obviously it should be fixable. What do you think people do if they have this problem in CA? They just get rid of the car? No way. |
02-16-2021, 09:53 AM | #18 | |
128
Rep 250
I did do drive cycles. Nothing. The first portion of it is “let the car idle for 2 minutes and 10 seconds, this should set the secondary air pump” |
02-16-2021, 12:02 PM | #19 | ||
5865
Rep 6,637
02-16-2021, 02:12 PM | #20 |
62
Rep 232
i found one of the best was to keep moving and get the cycle done in one shot was to drive on the freeway later night-early morning, and then drive through the airport terminal a couple times if you need. that way you dont ever have to complete stop midway through. worked for me at least, hopefully this works for you!
Ohlins | Swift | Vorshlag | Epic | Corsa | Evolve | Eventuri | Haimus Racing | BW | TMS | J-Fiber | Hotchkis | Do88 | RTD | BBS | Dinan | Ground Control |
02-16-2021, 03:19 PM | #21 |
567
Rep 801
Do you have an OBDII scanner? Something like this would let you watch the monitors live: https://www.amazon.com/Autel-MS309-U...omotive&sr=1-6
Remember: LIGHT throttle, LOW rpms. SMOOTH driving. My wife's 993TT is really hard to set the readiness monitors on. (They're famous for this.) Many drivers simply can't make themselves drive in a way that will set the last monitors. I've really had to practice this in order to succeed in that.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
02-16-2021, 06:12 PM | #22 |
88
Rep 163
I had to reflash from Stage 1 tune back to stock for smog check. As mentioned you need to be light on the throttle and smooth driving. All I did to get readiness set was drive up and down the freeway late at night staying between 55-60. Approx. 15 min one way, turn around and 15 min back. When I pulled back into the dwy, hooked up the OBDII scanner, all readiness monitors were set.
