04-14-2008, 03:12 AM | #3 |
152
Rep 5,124
dimensions are different. check bmwusa.com they should be able to give you the exact spec pics. or you could search on here, i know that they have been posted somewhere.
04-14-2008, 04:07 AM | #4 |
48
Rep 636
As far as I can tell from the dimensions, the front ends are the same. The only difference is from the rear wheel back, not counting the extra doors. The sedan has the back end chopped off about 3 inches.
04-14-2008, 04:55 AM | #5 |
152
Rep 5,124
the dimensions are NOT the same:
coupe tire centerline to tire centerline: 1538mm sedan tire centerline to tire centerline: 1539mm coupe mirror to mirror: 2005mm sedan mirror to mirror:1976mm from these websites: http://www.bmwusa.com/Standard/Conte...fications.aspx http://www.bmwusa.com/Standard/Conte...fications.aspx |
04-14-2008, 11:00 AM | #6 |
27
Rep 271
I know the dimensions of the two are not exactly the same, the sedan is a little shorter than the coupe and the sedan is a little wider than the coupe. I'm talking about the dimensions of the front end, the front bumper, the hood, the fenders, headlights, etc..... Thanks.......
04-14-2008, 11:07 AM | #7 | |
Racying Dynamics
118
Rep 4,391
