KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
12-10-2016, 06:12 AM | #1 |
33
Rep 122
Cold weather right pressure?
Hello, what should be the right psi on stock m3 e92 wheels during cold weather? Its about 29 degrees freezing here in VA and its showing low tire pressure. Stock showing 33 front and 35 rear. But not sure what should be for cold weather!?
12-11-2016, 10:44 PM | #2 |
503
Rep 1,055
Air pressure generally should be kept the same regardless of outddoor temp.
Given that, cold weather will cause your tire pressure to decrease so you normally have to add air to bring it back up to normal pressure in the winter. This doesn't mean that you run different pressure because its cold out. |
12-12-2016, 01:08 AM | #3 |
11589
Rep 12,732
i don't have to deal with this [california], but i probably wouldn't mess with your tire pressure. our temperature range in socal is about 33-90* depending on the time of year. in the winter, we get tpms errors as well. just took a call from my girlfriend asking about her tpms light today, actually. tpms isn't perfect and occasionally puts up false errors when it is cold. they aren't actually false, because although you don't have a leak, your tire pressure is fluctuating a little bit.
here is why i would keep it the same, when tire pressure is lower, your tire's contact patch is more flat, which means more grip in snow/ice conditions. too little pressure isn't good though, as it wears on your sidewalls. so, check your pressures from each of your tires from time to time to make sure you didn't pickup a nail, but i would probably keep it the same.
Instagram; @roastbeefmike
