11-30-2016, 01:13 PM | #1 |
BimmerPost Supporting Vendor
9595
Rep 10,883
New release: MACHT SCHNELL - BOOST METERING BLOCK
Any S55 owner interested in serious boost increases has run into a difficulty in getting a standalone vacuum/boost reading from the engine. As with most modern engines, the S55 does not have spare vacuum nipples which can easily be tapped for a boost reference, making things difficult when the S55's boost output is dramatically increase. Now Macht Schnell has created an inexpensive, easy to install solution. The Macht Schnell Boost Metering Block is a bolt-on installation without the need for drilling or tapping into factory charge pipes. Comes complete with O-rings and extended-length screws for simple installation in minutes. The Boost Metering Block is essential for boost readings while on the dyno, or for connecting an analog Boost pressure/vacuum gauge on the dyno. When not in use, the included rubber cap will properly seal the port off safely.
11-30-2016, 03:44 PM | #3 |
9595
Rep 10,883
3D Design does have a gauge pod available!
11-30-2016, 06:21 PM | #5 |
1326
Rep 1,481
12-01-2016, 11:28 AM | #6 |
9595
Rep 10,883
Correct! The cup holders are technically retained, but the gauges will not clear all cups.
12-02-2016, 08:19 AM | #7 |
289
Rep 1,575
No big gulps people!
12-02-2016, 08:51 AM | #8 |
#LSBM3
1421
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Dig it! Just wish they would have included a 90* degree elbow for the vacuum inlet in the kit so that you can easily route the vacuum line back towards the firewall.
/// M3 |
humbertin089.00 |
12-02-2016, 08:53 AM | #9 |
Gone Fishin
7318
Rep 12,125
12-02-2016, 09:13 AM | #10 | |
3348
Rep 2,009
https://www.amazon.com/gp/product/B0...7E5OLQ67NVPFZA Collapsible |
12-02-2016, 09:21 AM | #11 | |
89
Rep 440
EDIT: I think there are "swivel" type of 90* pneumatic elbows, but they're pretty robust |
12-02-2016, 11:39 AM | #12 | |
#LSBM3
1421
Rep 1,973
Drives: 2016 BMW M3
On a side note, this Mach Schnell piece seems to be a rebranded version of a generic that is available on AliExpress for $12.39. You can also find them on eBay for around $25.
/// M3 Last edited by Brasko; 12-02-2016 at 11:45 AM.. |
12-02-2016, 12:17 PM | #13 | |
119
Rep 180
I may need to buy one of those! |
humbertin089.00 |
12-02-2016, 12:32 PM | #14 |
#LSBM3
1421
Rep 1,973
Drives: 2016 BMW M3
Nice observation!
/// M3 |
12-02-2016, 12:52 PM | #15 |
89
Rep 440
