11-12-2016, 08:24 PM | #1 |
59
Rep 237
Drives: F90 M5, prior F80 M3, E60 M5
JB1 vs JB4 install..what the difficulty level
I have heard that JB1 is a bit tricky to install. How much more diff is JB4?
thanks |
11-13-2016, 05:53 AM | #2 |
1274
Rep 4,703
11-13-2016, 06:11 PM | #4 |
Rep 17
11-13-2016, 09:38 PM | #5 |
3348
Rep 2,009
Do a search for the jb4 supplemental guide there's a lot of good information in there that will help you install. It's also all about having the right tools. I recommend a 90 degree pick and that well help you pop the clips off easier. Also having some fish tape will help you run the OBDII connector through the firewall.
11-14-2016, 09:44 AM | #6 |
never could compete with Lloyd Braun
5276
Rep 5,378
+1 on the fuel mass connector being the biggest pain for me... and I have smaller joints and hands lol
The ODB wasn't bad at all for me but I have a DCT car which is a little less painful than a 6mt for that portion.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
11-14-2016, 06:24 PM | #8 | |
BimmerPost Supporting Vendor
24290
Rep 190,975
Both installs are easy and straightforward
11-15-2016, 10:47 AM | #9 |
634
Rep 1,048
JB4 + manual transmission was damn near impossible to get the ODB through the firewall. My friend and I worked on that piece alone for 2+ hours. We finally had to split the wires to get it pushed through. The Clutch cable takes up a ton of space.
11-15-2016, 12:32 PM | #10 |
34
Rep 155
Fuel sensor connector was very easy cant see how it was difficult for others just turn swap connectors then turn back,worst part was getting that obd2 cable thru firewall in my manual car and no instructions anywhere ..
i used a wire coat hanger put it thru that clutch hole then tape the small obd connector to coat hanger pull out slowly and move wire around till it comes out |
11-15-2016, 10:18 PM | #11 |
167
Rep 332
Simply put, its super easy as long as you have patience and a long set of pliers.
2023 BMW M2 G87
Previous M's: 2016 BMW M3 DCT 2008 BMW M3 Saloon |
11-18-2016, 02:06 PM | #13 |
Joint Chiefs of Staff
4920
Rep 115,999
The JB4 and JB1 have identical installs other ethen the JB4 has the CAN Connection you route under the dash and the optional mass fuel sensor you can connect.
Mike |
