10-17-2016, 03:16 PM | #1 |
264
Rep 748
Supreme Power | Your Local One-Stop Shop
SUPREMEPOWER 1562 Kimberly Ave, Fullerton, CA 92831 Fullerton CA (714)632-1951 matt@supremepower.com About Us: SUPREMEPOWER™ is your 1-stop shop for on-road parts and accessories. Our goal is to give you a great experience & total customer satisfaction! We have been serving the aftermarket industry of over 15 years (Est. 1999)! Our knowledge and experience is unsurpassed. We offer advice and don't pressure sell you like our competitors. Understanding our customers' needs and getting them fitted with the perfect parts is what we are known for. One-Stop Shop: Here at Supreme Power we can perform any maintenance job, performance upgrade, and everything in between. We work on all makes and models in our 10,000 sq/ft facility with 5 lifts, 2 Road Force Balancers, a Corghi Touchless Tire Mounter, a Walnut Blaster for Direct Injected Engines, and a Hunter In-Ground Alignment Rack. We install everything we sell. In House Alignment Rack: Uneven tire wear? No Problem. We have an IN GROUND Hunter Alignment Rack in our facility here in Placentia, CA. Alignments are crucial after any spring/coilover installation and we got you covered! With an in ground alignment rack, you won't have to worry about clearance issues if you are lowered. Hunter Road Force wheel balancer: Are you having vibration symptoms? We can diagnose and a perform vibration test on our Road Force balancer. We will eliminate or determine your issue. The Road Force wheel balancer features SmartWeight balancing technology and a patented BullsEye centering system so you can trust that wheels are balanced correctly every time. We work on all make and models. Don't be afraid to contact us. No task is too small for us! Address: Supreme Power 1562 Kimberly Ave, Fullerton, CA 92831 Hours of Operations: Mon - Fri: 9am to 6pm (PST) Saturday: By Appointment Sunday: Closed Contact Info: Phone: (714) 632-1951 Email: matt@supremepower.com Website: http://www.supremepower.com Instagram: @Supremepower Facebook: https://www.facebook.com/SupremePowerInc?fref=ts Last edited by matt@supremepower; 08-31-2018 at 02:11 PM.. |
10-18-2016, 04:15 PM | #3 |
11586
Rep 12,728
did you guys move? weren't you guys in norcal or something?
what would you guys charge to road force balance four wheels?
Instagram; @roastbeefmike
10-18-2016, 06:27 PM | #4 |
264
Rep 748
10-24-2016, 07:48 PM | #7 |
264
Rep 748
Lots of E9X at the shop today.
700+ WHP 335i Pure Stage 2 Turbo Upgrade, Port Injection 100% E85 E90 335i In for an engine replacement. (Will keep updating) Dropping in an engine from a 2010 135i, along with an 8-Bolt DMFW, 335is/550i Clutch, VRSF OEM Location Silicone Inlets, and brand new OEM Replacement Turbos. E91 on Vossen, lowered on Bilstein. |
11-16-2016, 07:11 PM | #12 |
264
Rep 748
We had a customer come in stating he was hearing a knocking sound on his M3.
We had him come in and got his car on the lift. After dropping the subframe and oil pan, we were able to access and remove the rod bearings. Doesn't look good... If this issue is left untreated, it can and will cause damage to the crankshaft which is an even bigger repair. In this particular case, the crankshaft shows severe damage. The engine will need to be removed and crank/bearings replaced. |
05-09-2017, 05:29 PM | #14 |
264
Rep 748
05-12-2017, 01:53 PM | #20 |
122
Rep 451
Drives: 09'M3, 16'M3, 11'550i, 17'X5
Do you guys rebuild actuators?
2009 Grigio Telesto M3 DCT. ESS 700, BPM Tuned, GTS Tune w/ Euro MDM, Catless custom exhaust, TE37SL/Rays G07EX, Amuse Ericsson Bumper, CSL Carbon Trunk
2016 M3. JB4, VRSF Downpipes, Custom exhaust, Cornfed 2011 550i. Dinan Stage 3, JB4 Piggyback, Catless Downpipes, Custom Exhaust 2017 X5 35i. STOCK, boring, and sold! |
